isoment01
- 26 Haz 2016
- 197
- 1
- Yaş
- 32
C:
* @file GPIO_Toggle\main.c
* @author MCD Application Team
* @version V2.0.4
* @date 26-April-2018
* @brief This file contains the main function for GPIO Toggle example.
* @attention
* <h2><center>© COPYRIGHT 2014 STMicroelectronics</center></h2>
* Licensed under MCD-ST Liberty SW License Agreement V2, (the "License");
* You may not use this file except in compliance with the License.
* You may obtain a copy of the License at:
* http://www.st.com/software_license_agreement_liberty_v2
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
/* Includes ------------------------------------------------------------------*/
#include "stm8s.h"
* @addtogroup GPIO_Toggle
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Evalboard I/Os configuration */
#define LED_GPIO_PORT (GPIOC)
#define LED_GPIO_PINS (GPIO_PIN_7 | GPIO_PIN_6 | GPIO_PIN_5 | GPIO_PIN_4 | GPIO_PIN_3)
#define BUTTON_PORT (GPIOD)
#define BUTTON_PIN_UP (GPIO_PIN_4)
#define BUTTON_PIN_DOWN (GPIO_PIN_5)
#define PRESSED 0
#define BUTTON_DEBOUNCE_TIME 16000
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
void Delay (uint16_t nCount);
/* Private functions ---------------------------------------------------------*/
/* Public functions ----------------------------------------------------------*/
* @brief Main program.
* @param None
* @retval None
void main(void)
/* Initialize I/Os in Output Mode */
GPIO_Init(LED_GPIO_PORT, (GPIO_Pin_TypeDef)LED_GPIO_PINS, GPIO_MODE_OUT_OD_LOW_FAST);
GPIO_Init(BUTTON_PORT, (GPIO_Pin_TypeDef)BUTTON_PIN_UP,GPIO_MODE_IN_FL_NO_IT);
GPIO_Init(BUTTON_PORT, (GPIO_Pin_TypeDef)BUTTON_PIN_DOWN, GPIO_MODE_IN_FL_NO_IT);
int Dimdizi[12] = {248, 56, 152, 232, 40, 136, 112,208, 16, 160, 64, 0}; // %0 den %100'e kadar ki dim voltajları
int i =0;
int y =0;
char status1= 1;
char status2= 1;
while (1)
// Check button status
if ((GPIO_ReadInputData(BUTTON_PORT) & BUTTON_PIN_UP) == PRESSED )
for(y=0; y<BUTTON_DEBOUNCE_TIME; y++);
if( status1==1)
status1=0;
i++;
if(i>=11)
i=11;
// GPIO_Write( GPIOC, Dimdizi[i]);
else
status1=1;
if ((GPIO_ReadInputData(BUTTON_PORT) & BUTTON_PIN_DOWN) == PRESSED )
if( status2==1)
status2=0;
i--;
if(i<=0) i=0;
else
status2=1;
* @brief Delay
* @param nCount
* @retval None
void Delay(uint16_t nCount)
/* Decrement nCount value */
while (nCount != 0)
nCount--;
#ifdef USE_FULL_ASSERT
* @brief Reports the name of the source file and the source line number
* where the assert_param error has occurred.
* @param file: pointer to the source file name
* @param line: assert_param error line source number
* @retval None
void assert_failed(uint8_t* file, uint32_t line)
/* User can add his own implementation to report the file name and line number,
ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
/* Infinite loop */
while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
