16f628a simülasyonda çalışıyor bread bordda çalışmıyor
  • Konbuyu başlatan Konbuyu başlatan deşarj
deşarj
6 Eki 2020
C:
#include <16f628.h>
#fuses XT,NOWDT
#use delay(clock=4000000)
#use fast_io(b)
#use fast_io(a)
#define   arttir      pin_b0
#define   azalt       pin_b1
int birler=0,sayi=0;
const int hane[10]={0x00,0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09};
unsigned int8 duty_oran=0;
unsigned int8 hassasiyet=25;
Void buton_kontrol(){
set_pwm1_duty(duty_oran);
if(duty_oran>=240)
duty_oran=0;
void ayarla()
   set_tris_b(0x03);
   set_tris_a(0xc0);
void haneBul()
    birler=sayi%10;
void displayYaz()
    output_a(hane[birler]|(0b11100000));
    delay_ms(2);
void main()
  // setup_adc(ADC_CLOCK_DIV_2);
 //  setup_psp(PSP_DISABLED);
  // setup_spi(SPI_SS_DISABLED);
   //setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   setup_vref(FALSE);
   set_tris_b(0b00000011);
    set_tris_a(0b11110000);
  output_b(0x00);
  //output_a(0x00);
   ayarla();
setup_timer_2(T2_DIV_BY_16,254,1);
setup_CCP1(CCP_PWM);
   while(TRUE)
     haneBul();
      buton_kontrol();
      displayYaz();
            if(input(arttir))
         delay_ms(5);
         sayi++;
         if(sayi==10) sayi=0;
                  delay_ms(1);
if(duty_oran<250)
duty_oran+=hassasiyet;
if(duty_oran >= 240)
duty_oran=0;
         while(input(arttir))
         { displayYaz();
           if(input(azalt)&&sayi!=0)
         delay_ms(5);
         sayi--;
         haneBul();
         delay_ms(1);
if(duty_oran>0)
duty_oran-=hassasiyet;
         while(input(azalt)){displayYaz();
C:
#include <16f628.h>
#fuses XT,NOWDT
#use fast_io(b)
#use fast_io(a)
if(duty_oran>=240)
duty_oran=0;
void ayarla()
   set_tris_b(0x03);
   set_tris_a(0xc0);
void haneBul()
    birler=sayi%10;
void displayYaz()
    delay_ms(2);
void main()
   setup_vref(FALSE);
  output_b(0x00);
  //output_a(0x00);
   ayarla();
   while(TRUE)
     haneBul();
      buton_kontrol();
      displayYaz();
            if(input(arttir))
         delay_ms(5);
         sayi++;
                  delay_ms(1);
if(duty_oran<250)
duty_oran=0;
         { displayYaz();
         delay_ms(5);
         sayi--;
         haneBul();
         delay_ms(1);
if(duty_oran>0)
bi yardım eden çıkar umarım inada bindi :)
neden çalışmıyor reelde nerde yanlışım var
Ek olarak kristal ne bağladınız?
Kurduğunuz Devreyi gorebilir miyiz ? Kristal yanında kondansator ne kullandiniz?
Uzun zaman oldu piclerle uğraşmayalı bilgilerim eski fakat aklıma kristalin değeri uygunmu sorusu geldi , yada sağlammı?..
Benim başıma gelen durum kristal bacaklarindski kapasitorler kaliteli değilse osilator devresi calismiyor. Bir keresinde 2 adet 22pf paralel bağladım ancak çalıştı devre.
zimbirti_zimbirti
