4 kademeli dimmer
aşağıdaki tam olarak da sizin yukarıdaki tarifinize göre çalışmaktadır.
( sensor / buton ları b7,b6,b5,b4 e bağlamanız gerekecek)
not: ISIS de denenmiştir. (buton arklarına karşı önlem almanız tavsiye edilir)
#include <16F628A.h>
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES NOBROWNOUT
#FUSES NOLVP
#use delay(int=4000000)
#use fast_io(a)
#use fast_io(b)
#define yuzde_25_artis 50
#define max_pwm_degeri 197
#define min_pwm_degeri 10000
int16 pwm_duty_degeri;
int8 sensor_degeri;
int8 old_sensor_degeri;
#int_RB
void RB_isr(void) {
sensor_degeri=input_b();
sensor_degeri>>=4;
if(sensor_degeri==12){sensor_degeri=8;}
if(sensor_degeri==6){sensor_degeri=4;}
if(sensor_degeri==3){sensor_degeri=2;}
if(sensor_degeri > 0)
if((pwm_duty_degeri==0) && (sensor_degeri==1)){pwm_duty_degeri += yuzde_25_artis;}
else if(sensor_degeri > old_sensor_degeri){pwm_duty_degeri += yuzde_25_artis;}
else if(sensor_degeri < old_sensor_degeri){pwm_duty_degeri -= yuzde_25_artis;}
else if(sensor_degeri == old_sensor_degeri){pwm_duty_degeri -= yuzde_25_artis;}
if(pwm_duty_degeri > min_pwm_degeri){pwm_duty_degeri = 0;}
if(pwm_duty_degeri > max_pwm_degeri){pwm_duty_degeri = max_pwm_degeri;}
set_pwm1_duty((int16)pwm_duty_degeri);
old_sensor_degeri = sensor_degeri;
void main() {
setup_timer_2(T2_DIV_BY_1,49,1);
setup_ccp1(CCP_PWM);
set_pwm1_duty((int16)0);
setup_comparator(NC_NC_NC_NC);
setup_oscillator(OSC_4MHZ);
enable_interrupts(INT_RB);
enable_interrupts(GLOBAL);
set_tris_a (0b11111111);
set_tris_b (0b11110111);
sensor_degeri=0;
old_sensor_degeri=0;
pwm_duty_degeri=0;
while(TRUE){}
// PROĞRAM AMACI (2 SENSÖRE TEK PARMAKLA DOKUNULUCAK YAKINLIK)
// 4 ADET SENSÖRLE PARMAKLARI ÜZERİNDE KAYDIRARAK PWM DE(IŞIKTA)
// ARTIRMA VE AZALTMA YAPMAK.
// PWM 20 KHZ OLARAK AYARLANMIŞTIR. GÜRÜLTÜ (SES) OLUŞTURACAK BİR DEVRE OLURSA
// İNSAN DUYMA FREKANSINDAN YÜKSEK OLDUĞU İÇİN DUYULMAYACAKTIR.
//HER HANGİ BİR SENSÖRDEN/BUTONDAN BASLANARAK YUKARI YADA AŞAĞI KAYDIRMA YAPILARAK
//PWM DEĞERİ DEĞİŞTİRİLİR.
//SENSÖRLER / BUTONLAR RB7,RB6,RB5,RB4 PİNLERİNE SIRAYLA BAĞLANMALIDIR
//SONSUZ DÖNGÜ İÇERİSİNDE İSTENİRSE. BUTONA HAREKET ETMEDEN X SANİYE BASILI TUTULUNCA EN SON
//YAPTIĞIN İŞLEMİ HIZLANDIR YADA EN UÇ SEVİYEYE GETİR GİBİSİNDEN BİR FONKSİYON AYARLARSANIZ.
//DAHA ESTEDİK VE KULLANIŞLI OLUR.
//MESELA; IŞIĞIN ŞİDDETİNİ BİRAZ KISIYORUZ AMA ELİMİZİ 2 SANİYE ÇEKMİYORUZ/HAREKET ETTİRMİYORUZ
//IŞIK TAMAMEN SÖNSÜN. GİBİ.
#device adc=16
#FUSES NOWDT //No Watch Dog Timer
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOBROWNOUT //No brownout reset
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#use delay(clock=4000000)
#use fast_io(a)
#use fast_io(b)
#define artirma_azaltma 20 // HER PARMAK KAYDIRMASINDA ARTACAK YADA AZALACAK DEĞER
#define max_pwm_degeri 197 // PWM_DUTY İN ALABİLECEĞİ EN FAZLA DEGER
#define min_pwm_degeri 10000 // PWM_DUTY 0 DAN DÜSÜSTE TEKRAR 0 A ÇEKİLMESİ İÇİN DEGER
int8 sensor_degeri;
int8 eski_sensor_degeri;
// PORT B PİN 4-7 DEĞİŞİMİNDE OLUŞACAK OLAN KESME
#int_RB
void RB_isr(void) {
sensor_degeri=(input_b()& 0b11110111);
sensor_degeri>>=4;
//sensorlere basma lar göz önünde bulundurulursa pin7 den pin 4 de doğru
//parmağımızı kaydırırsak sensör değeri sırayla şu degeri alır
// 01000(8),
// 01100(12),
// 00100(4),
// 00110(6),
// 00010(2),
// 00011(3),
// 00001(1),
//aşağıdaki kaydırma işleminden sonra değerler böyle olur;
// 10000(16),
// 01100(12),
// 01000(8),
// 00110(6),
// 00100(4),
// 00011(3),
// 00010(2);
// görüldüğü gibi sayılar büyükten küçüğe sıralanmış oldu.
if(sensor_degeri==8){sensor_degeri<<=1;} //8 ise 16 yap
if(sensor_degeri==4){sensor_degeri<<=1;} //4 ise 8 yap
if(sensor_degeri==2){sensor_degeri<<=1;} //2 ise 4 yap
if(sensor_degeri==1){sensor_degeri<<=1;} //1 ise 2 yap
if(eski_sensor_degeri > 0) //sensörlerden el çekilmediyse. yani ilk dakunuş değilse.
//sensör değeri eskisine nazaran artıyorsa pwm i artırıyoruz azalıyorsa azaltıyoruz
if(sensor_degeri > eski_sensor_degeri){pwm_duty_degeri += artirma_azaltma;}
if(sensor_degeri < eski_sensor_degeri){pwm_duty_degeri -= artirma_azaltma;}
// pwm değeri 0 ın altına düştüyse yani çok yüksek bir rakam olduysa 0 a sabitliyoruz.
// pwm değeri maX değeri aştıysa max değere sabitliyoruz.
//elde ettiğimiz pwm duty değerini pwm e uyguluyoruz
// tekrar karşılaştırma yapabilmek için sensör değerini eski sönser değişkenine aktarıyoruz
eski_sensor_degeri = sensor_degeri;
void main() {
setup_timer_2(T2_DIV_BY_1,49,1); //50.0 us kesme (20 khz pwm için)
setup_timer_1(T1_DISABLED); // timer 1 dahili saat ve bölme 1
set_pwm1_duty((int16)0); //maksimum pwm=197 olabilir
while(TRUE){
//eğer sensorlere dokunulmuyorsa eski sensor değerini sıfırla
// pwm çıkışını okuyUp okumadığı aklımda değil ben her ihtimale karşı
// pin 3 ü perdeliyorum.
if((input_b()& 0b11110111)== 0)
eski_sensor_degeri = 0;
merhaba kolay gelsin. devreye şu şekilde ekleme yapabilrimiyiz. devre şuan güzel çalışıyor. her butona bir led baglayacaz. 1. butona bastıgımız zaman led yanacak ve %25 parlaklık olacagını bilecez. aynı şekilde diğer butonlarad bu şekilde gerçekleşecek.ikinci butona bastıgımız zaman 2 led yanacak. 3. butona bastıgımız zaman 3. led yanacak 4. butona bastıgımız zaman 4. led yanacak.tekrara geiye de aynı şeklde sönecek.
kolay gelsin.
tabiki istediğiniz şekilde buton / led kontrolü yapabilirsiniz.
a: bastığınız butona karşılık gelen led in yanması mı?(örneğin; 1. butona bastım, 1. led yanacak. 2. butona bastım 2. led yanacak.....)
b: led in parlaklığına (yani pwm e) karşılık gelen led in yanması mı? (örneğin; %0 duty için hiç birled yanmayacak. %25 duty için 1. led yanacak. %50 duty için 2. led yanacak......)
c: led in parlaklığına (yani pwm e) karşılık gelen ledlerin hepsinin yanması mı? (örneğin; %0 duty için hiç led yanmayacak. %25 duty için 1. led yanacak. %50 duty için 1. ve 2. led yanacak. %75 duty için 1. ve 2. ve 3. led ler yansın......)
benim tavsiyem (c:) şıkkıdır. (ve ona göre duty in degerine göre basit if - else if kontrolü yapıp çıkışları yonlendireceğiz.)
if-else komutları içerisindeki pin yönlendirmelerinde istediğin gibi değişiklik yapıp kullanabilirsiniz. değişik portlardan pin kullannabilirsiniz örneğin; pin_c1, pin_a3, pin_b2, pin_c5, kullanabilirsiniz.
#define led1 pin_xx
#define led2 pin_xx
#define led3 pin_xx
#define led4 pin_xx
if( pwm_duty_degeri > 75 )
output_high(led1);
output_high(led2);
output_high(led3);
output_high(led4);
else if ( pwm_duty_degeri > 50 )
output_high(led1);
output_high(led2);
output_high(led3);
output_low(led4);
else if( pwm_duty_degeri > 25 )
output_high(led1);
output_high(led2);
output_low(led3);
output_low(led4);
else if( pwm_duty_degeri > 0 )
output_high(led1);
output_low(led2);
output_low(led3);
output_low(led4);
else
output_low(led1);
output_low(led2);
output_low(led3);
output_low(led4);
yada led kontrolü için tek port kullanılacaksa bir dizi oluşturulup ; port kontrolüde yapabiliriz.
cons int8 ledler [4]={0x00,0x01,0x03,0x07,0x0F}; // degerler (0x00) = 0000 , (0x01) = 0001 , (0x03) = 0011 , (0x07) = 0111 , (0x0f) = 1111 // bir dizi oluşturup ledleri yakacak olan çıkış degerlerini yazıyoruz
pwm_duty_yuzde_yirmibes_degeri xx // maximum pwm in yüzde yirmibeşine denk gelen rakamı yazıyoruz. %25 den 1,2 deger aşağı olmasını tavsiye ederim. %25 i geçmesin.
bolu_deger = pwm_duty_degeri / pwm_duty_yuzde_yirmibes_degeri ;// 5 rakam yani 0,1,2,3,4 rakamlarını elde etmek için duty degerinin max dutyin %25 ine bölümü
output_A (ledler[bolu_deger]);// elde edilen bolu derine denk gelen yani pwm şiddetine denk gelen çıkışların aktif edilmesi
merhaba
verdiğini programı while(1){} komutundan sonra yazsam olur mu. yoksa while döngüsü içerisine mi yazmam gerekiyor.
kodu denedim.. sıkıntısız çalışıyor. pwm değerine göre çıkışlar aktif oluyor.
while (TRUE)
.....kodlar.......
..... kodlar...... yazan yere kodları yerleştirin. tanımlamaları kendi proğramınıza göre değiştirin.
while(TRUE){...} den sonra ne yazarsanız yazın çalışmayacaktır çünkü while (TRUE) şartını bozacak hiç bir durum yoktur. sadece kesmeye gider kesme işlemini yapar ve while (TRUE){...} şartını kontrol eder durur. işlemci tanımlamalarında "TRUE" (doğru) 1 olarak tanımlanmıştır. #define TRUE 1 ... yani while kontrolü sonsuz döngü olmuş oluyor. işlemci o kontrolü aşıp sıradaki işlemleri işlemez.
ister kodu while(TRUE){ kodlar buraya } olarak yaz.
istersen.
rb7 kesmesinde son süslü parantezden önce yaz.
void rb7_kesmesi (void)
pwm kontrol kodları
"ekleyeceğin kodlar buraya"
bu işlemlerden birini yapınca sıkıntısız çalışacaktır.
hocam merhaba,
ben tek buton ile spot led kontrolü yapmak istiyorum.
yardımcı olabilir miisiniz ? yapan arkadaşlar varsa devre şeması ve kod paylaşabilir mi ?
murat620
