89C52 ile LCD ye yazdırabiliyorum fakat PIC16F877 de yapamıyorum :(
ademcekic
30 Tem 2007
Merhaba arkadaşlar. Pic öğrenmeye çalışıyorum. Bayağı bir yol katettim fakat bir türlü LCD den görüntü alamadım.
89c52 kullanarak aynı LCD den görüntü alabiliyorum. Aşağıya 89c52 ile ekrana yazı yazdırdığım resmi ekledim. Ve hemen altında da asm kodu var.
EN EQU P3.0 ; The pin of LCD enable to the port of P3.0
RW EQU P3.1 ; The pin of LCD R/W to the port of P3.1
RS EQU P3.2 ; The pin of LCD RS to the port of P3.2
LCDDATA EQU P1 ; Databus of LCD to the port of P1
BUTON EQU R7
ORG 0 ; Starting address of program
INIT_MAIN:
MOV SP,#30H ; Starting address of stack pointer
MOV P0,#255 ; P0 = input
MOV R0,#3 ; Repeats the LCD initialization 3 times at the beginning
MOV P1,#0 ; P1 = output
MOV P3,#0 ; P3 = output
MOV P2,#255
MOV P3,#15 ; LCD illumination on, P3.4 = P3.5 = P3.6 = 0 = output
INIT_LCD: ; Performing LCD's initialization adjustments
MOV A,#38h ; Function set, (20h), 8 bit databus (10h),
ACALL SENDCOMMAND ; Two lines display (08h)
MOV A,#0Ch ; Display and cursor control command, LCD on
ACALL SENDCOMMAND ; Cursor off
MOV A,#06h ; Entry mode, shifts cursor's position to the right
ACALL SENDCOMMAND ; for one character after each data automatically
DJNZ R0,INIT_LCD
CLEAR_LCD: ; This subroutine clears the data RAM and display
CLR RS
SETB EN
MOV LCDDATA,#01h
CLR EN
ACALL WAIT_LCD
MOV A,#85H ; 9AH, the address of 1rd line and 6th character,
ACALL SENDCOMMAND ; is sent to the LCD as a command
MOV A,#'H' ; Writes "HELLO" on display
ACALL WRITE_TEXT ; starting from 1rd line and 6th character
MOV A,#'E'
ACALL WRITE_TEXT
MOV A,#'L'
ACALL WRITE_TEXT
MOV A,#'L'
ACALL WRITE_TEXT
MOV A,#'O'
ACALL WRITE_TEXT
MAIN:
AJMP MAIN
RET
SENDCOMMAND: ; The subroutine to send command to microcontroller
CLR RS
SETB EN
MOV LCDDATA, A
CLR EN
ACALL WAIT_LCD
RET
WRITE_TEXT:
SETB RS ; The subroutine to send text to the LCD
SETB EN
MOV LCDDATA,A
CLR EN
ACALL WAIT_LCD
RET
WAIT_LCD:
CLR EN
CLR RS
SETB RW ; Read command
MOV LCDDATA,#0FFh ; Prepare all the buses for input
SETB EN
MOV A,LCDDATA ; Read the value
JB ACC.7,WAIT_LCD ; If bit 7 is still high, then the LCD is still busy
CLR EN ; Otherwise terminate the command
CLR RW
RET
END
Fakat 16F877 ile başaramadım. Pic i taktığımda aşağıdaki ekrandan başka bir şey gelmiyor ekrana. ASM kodu da aşağıda. Nerede hata yaptığımı anlamadım. Yardımınızı bekliyorum.
; LCD ÇALIŞTIRILAMADI. 13.03.2011 13:03
list p=16F877
include "p16F877.inc"
__config H'3F31' ;PWRT on, diğerleri kapalı,
;Osilatör XT ve 4Mhz
cblock 0x20
R0
R1
R2
endc
#define LCDDATA PORTD
#define LCDCONTROL PORTC
#define RS 5 ;LCD RS pini RC4'e bağlı.
#define RW 6 ;LCD RW pini RC6'ya bağlı.
#define EN 7 ;LCD E pini RC5'e bağlı.
org 0 ; Start at flash address 0
CALL INIT_MAIN
CALL INIT_LCD
CALL CLEAR_LCD
CALL HELLO_YAZ
MAIN:
GOTO MAIN
INIT_MAIN:
bsf STATUS,RP0 ; Select Registers at Bank 1
movlw b'00000000' ; Set port to OUTPUT
movwf TRISC ; PORTC = LCD KONTROL UÇLARI
MOVWF TRISD
bcf STATUS,RP0
MOVLW D'3'
MOVWF R0 ; Repeats the LCD initialization 3 times at the beginning
RETURN
INIT_LCD: ; Performing LCD’s initialization adjustments
MOVLW H'38' ; Function set, (20h), 8 bit databus (10h),
MOVLW H'0C' ; Display and cursor control command, LCD on
MOVLW H'06' ; Entry mode, shifts cursor’s position to the right
DECFSZ R0,F
GOTO INIT_LCD
BCF PORTB,7
RETURN
BCF LCDCONTROL,RS
BSF LCDCONTROL,EN
MOVLW D'1'
MOVWF LCDDATA
BCF LCDCONTROL,EN
CALL WAIT_LCD
RETURN
HELLO_YAZ:
MOVLW A'H' ; the address of FİRST line and FİRST character,
MOVLW A'E' ; Writes “WELCOME” on display
CALL WRITE_TEXT ; starting from 3rd line and 6th character
MOVLW A'L'
CALL WRITE_TEXT
MOVLW A'L'
CALL WRITE_TEXT
MOVLW A'O'
CALL WRITE_TEXT
RETURN
SENDCOMMAND:
BCF LCDCONTROL,RS ; The subroutine to send command to microcontroller
BSF LCDCONTROL,EN
MOVWF LCDDATA
BCF LCDCONTROL,EN
CALL WAIT_LCD
RETURN
WRITE_TEXT:
BSF LCDCONTROL,RS ; The subroutine to send text to the LCD
BSF LCDCONTROL,EN
MOVWF LCDDATA
BCF LCDCONTROL,EN
CALL WAIT_LCD
RETURN
WAIT_LCD:
BCF LCDCONTROL,EN
BCF LCDCONTROL,RS
BSF LCDCONTROL,RW ; Read command
MOVLW B'11111111' ; Prepare all the buses for input
MOVWF TRISD ;
bcf STATUS,RP0
BTFSC LCDDATA,7 ; If bit 7 is still high, then the LCD is still busy
GOTO WAIT_LCD
BCF LCDCONTROL,EN ; Otherwise terminate the command
BCF LCDCONTROL,RW
MOVLW D'0' ; Prepare all the buses for output
MOVWF TRISD ; Read the value
bcf STATUS,RP0
RETURN
END
Yardımcı olabilecek kimse yok sanırım. Neyse ben bulursam sizlerle paylaşırım. Teşekkürler.
BSF LCDCONTROL,EN
MOVWF LCDDATA
BCF LCDCONTROL,EN
CALL WAIT_LCD
RETURN
Tam olarak kontrol etmek için fırsatım olmadı yanlız lcd için önce data yükle sonra LCDCONTROL,EN bsf yap.
Yani;
MOVWF LCDDATA
BSF LCDCONTROL,EN
NOP
NOP
BCF LCDCONTROL,EN
CALL WAIT_LCD
RETURN
aynı şeyi karakter yollamada ve komut yollamadada bu şekilde kullan.
Hemen deniyorum :)
Maalesef değişen birşey olmadı. Yine üst satır karanlık olarak gözüküyor. Ekranda yazı yazmıyor.
Ben sana kodlar yollayayım.
Kendi hatanı kendin bul. Bu rutinleri her yerde kullanabilirsin. Daha açık bir kod bekleme. :)
;======= TANIMLAMALAR ===================================;
#DEFINE
LCD_DATA PORTB
#DEFINE
LCD_RS PORTB,2
#DEFINE
LCD_EN PORTB,3
;===== C BLOCKLAR =======================================;
LCD_TMP
LCD_TMP1
;******* BAŞLANGIÇ NOKTASI ******************************; ;********************************************************;
CALL Lcd_Init
basla
;***** 1. SATIRI YAZ ************************************;
MOVLW
b'10000000'
CALL
Komut_Yaz
MOVLW 'H'
CALL Karakter_Yaz
MOVLW
'E'
CALL
Karakter_Yaz
MOVLW 'L'
CALL Karakter_Yaz
MOVLW 'L'
CALL
Karakter_Yaz
MOVLW 'O'
CALL Karakter_Yaz
;***** 2. SATIRI YAZ ************************************;
MOVLW b'11000000'
CALL
Komut_Yaz
MOVLW
'N'
CALL Karakter_Yaz
MOVLW 'E'
CALL Karakter_Yaz
MOVLW 'H'
CALL Karakter_Yaz
MOVLW 'A'
CALL Karakter_Yaz
MOVLW 'B'
CALL
Karakter_Yaz
MOVLW
'E'
CALL Karakter_Yaz
MOVLW 'R'
CALL Karakter_Yaz
MOVLW '!'
CALL Karakter_Yaz
bitti
CLRWDT
GOTO
bitti
;***** LCD RUTİNLERİ ************************************; ;********************************************************;
Lcd_Tek_Yolla
ANDLW 0xF0
MOVWF
LCD_TMP1
MOVF
LCD_DATA,W
ANDLW 0x0F
IORWF LCD_TMP1,W
MOVWF LCD_DATA
BSF LCD_EN
CALL _5us
BCF LCD_EN
CALL _50us
RETURN
Komut_Yaz
MOVWF
LCD_TMP
BCF LCD_RS
CALL
Lcd_Tek_Yolla
CALL _1ms
SWAPF LCD_TMP,W
BCF LCD_RS
CALL Lcd_Tek_Yolla
CALL _1ms
RETURN
Karakter_Yaz
MOVWF
LCD_TMP
BSF LCD_RS
CALL Lcd_Tek_Yolla
SWAPF LCD_TMP,W
BSF LCD_RS
CALL
Lcd_Tek_Yolla
RETURN
Lcd_Init
BCF
LCD_RS
MOVLW
0x30
CALL
Lcd_Tek_Yolla
CALL _1ms
MOVLW
0x20
CALL Lcd_Tek_Yolla
CALL _1ms
MOVLW 0x28
CALL Komut_Yaz
MOVLW 0x0c
CALL Komut_Yaz
RETURN
;***** GEREKLİ ZAMANLAR *********************************;
;===== 5us BEKLE =====================================;
_5us
;===== 50 us BEKLE ===================================;
_50us
;===== 1ms BEKLE =====================================;
_1ms
END
Bu arada lcd-rw yi artıya çek. lcdden bişey okumadığım için gerek duymadım. ;)
Merhaba. Yukarıdaki programınız 4-bit veriyollu ve RW ucu kullanılmıyor. Benim istediğimse;
Lcd databus = Portd
RW pinini de kullanarak
ve 8-bit veriyolu
olacak şekilde 16f877 yi kullanarak en azından lcd yi init edebilen bir programı burada paylaşabilir misiniz?
Programlama bilgim hiç yok sanılmasın. Sadece bir ayrıntıyı atlıyorum fakat hala bulamadım. Yardımınızı bekliyorum.
Akrazi hocam çok teşekkür ederim yardımların için. Lcd den sonunda görüntü aldım. Fakat lcddatabus olarak portc yi veya portb yi kullandığımda çalıştırabiliyorum fakat portd yi lcddatabus yaptığımda çalıştıramıyorum. Bunun nedeni hakkında bilgisi olan var mı acaba? Portd nin farklı bir init konfigürasyonu mu var?
Yates
