Arduino 74HC595 Çıkışları tek tek ayarlayamıyorum
  • Konbuyu başlatan Konbuyu başlatan Affansen
Affansen
Katılımcı Üye
15 Ocak 2021
74HC595 entegresini Arduino ile kullanıyorum. İnternetteki örneklere baktığım zaman örneklerde hep kayar led yapılmış. Kayar led uygulamaları başarıyla çalıştı ancak çıkışları tek tek kontrol edemedim.
C++:
int latchPin = 5;  // Latch pin of 74HC595 is connected to Digital pin 5
int clockPin = 6; // Clock pin of 74HC595 is connected to Digital pin 6
int dataPin = 4;  // Data pin of 74HC595 is connected to Digital pin 4
byte leds = 0;    // Variable to hold the pattern of which LEDs are currently turned on or off
 * setup() - this function runs once when you turn your Arduino on
 * We initialize the serial connection with the computer
void setup()
  // Set all the pins of 74HC595 as OUTPUT
  pinMode(latchPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
 * loop() - this function runs over and over again
void loop()
  leds = 0; // Initially turns all the LEDs off, by giving the variable 'leds' the value 0
  updateShiftRegister();
  delay(500);
  for (int i = 0; i < 8; i++) // Turn all the LEDs ON one by one.
    bitSet(leds, i);    // Set the bit that controls that LED in the variable 'leds'
    delay(500);
 * updateShiftRegister() - This function sets the latchPin to low, then calls the Arduino function 'shiftOut' to shift out contents of variable 'leds' in the shift register before putting the 'latchPin' high again.
void updateShiftRegister()
   digitalWrite(latchPin, LOW);
   shiftOut(dataPin, clockPin, LSBFIRST, leds);
   digitalWrite(latchPin, HIGH);
8-bit bilgi yolluyorsunuz. Her defasınında
bu bitleri birleştirip bir byte yollayacaksınız.
Basit bir örnek:
Kod:
typedef struct {
   unsigned int d0:1;
   unsigned int d1:1;
   unsigned int d2:1;
   unsigned int d3:1;
   unsigned int d4:1;
   unsigned int d5:1;
   unsigned int d6:1;
   unsigned int d7:1;
} bit_a;
int main(void)
   bit_a bita_var;
   bita_var.d0 = 0b1;
   bita_var.d1 = 0b0;
   HC595_yaz(bita_var);
   return 0;
tarntula_tr
