Arduino IR sensor kod derleme hatası
Affansen
Katılımcı Üye
15 Ocak 2021
Nedenini bilmediğim bir şekilde mBlock ile IR kumanda kodu yaparken hata alıyorum. Kodu Arduino IDE ile açınca ise şu hatayı alıyorum:
Kod:
Arduino:1.6.5 (Windows 8.1), Kart:"Arduino/Genuino Uno"
IRremote_ard.cpp.o: In function `MATCH(int, int)':
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `MATCH(int, int)'
IRremoteNEW.cpp.o:D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremoteIntNEW.h:176: first defined here
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `MATCH_MARK(int, int)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `MATCH_SPACE(int, int)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::IRrecv(int)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `irparams'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::enableIRIn()'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::blink13(int)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `__vector_7'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::resume()'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::decodeNEC(decode_results*)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::getRClevel(decode_results*, int*, int*, int)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::compare(unsigned int, unsigned int)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::decodeHash(decode_results*)'
D:\Users\AFFAN\AppData\Local\Temp\build3132428152192588699.tmp/IRremote_ard.cpp:69: multiple definition of `IRrecv::decode(decode_results*)'
collect2.exe: error: ld returned 1 exit status
Derleme sırasında hata oluştu.
  Rapor daha fazla veri içermeli
  "Derleme sırasında ayrıntılı çıktı göster"
  Dosya > Tercihler'de etkinleştirilmiş.
@Akif9748
IRremote_ard.cpp
IRremoteIntNEW.h
içerisinde aynı fonksiyonlar var diyor ikisinden birisi fazla yüklenmiş. Yazdığın kodu paylaşırsan çözüm ararız
IRremote_ard.cpp
IRremoteIntNEW.h
Cevabınız için teşekkür ederim, deneyeceğim hemen.
Normalde IDE kodunda bir sorun yok. Problem mBlock ile başlıyor. :D
dkaplanoglu
