Arduinoda yardım istiyen gelebilir
Arduino çok çok çokkk basit bence pıc den önce Arduino ile başlayın daha mantıklı hiç tecrübeniz yok ise
Merhaba, bir butonla 5 adet farklı frekans üretip Lcd ekranda frekansı yazdırmam gerekiyor, 2 parça örnek koda sahibim ama ana koda nasıl adapte edeceğim konusunda destek rica edeceğim.
Kod:
const byte LED = 3;  // Timer 2 "B" output: OC2B
const long frequency = 12500L;  // Hz
void setup()
  pinMode (LED, OUTPUT);
  TCCR2A = _BV (WGM20) | _BV (WGM21) | _BV (COM2B1); // fast PWM, clear OC2B on compare
  TCCR2B = _BV (WGM22) | _BV (CS21);         // fast PWM, prescaler of 8
  OCR2A =  ((F_CPU / 8) / frequency) - 1;    // zero relative
  OCR2B = ((OCR2A + 1) / 2) - 1;             // 50% duty cycle
  }  // end of setup
void loop() { }
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x27,16,2);  // set the LCD address to 0x27 for a 16 chars and 2 line display
int WhichScreen =1;   // This variable stores the current Screen number
boolean hasChanged = true;
const int buttonPin = 4;    // the number of the pushbutton pin
int buttonState;             // the current reading from the input pin
int lastButtonState = LOW;   // the previous reading from the input pin
unsigned long lastDebounceTime = 0;  // the last time the output pin was toggled
unsigned long debounceDelay = 50;    // the debounce time; increase if the output flickers
void setup()
  lcd.init();// initialize the lcd
  lcd.backlight();
  pinMode(buttonPin, INPUT);
void loop()
  if (hasChanged == true) {
  switch(WhichScreen) {
    case 1:
      firstScreen();
      break;
    case 2:
        secondScreen();
      break;
    case 3:
        thirdScreen();
      break;
    case 4:
        fourthScreen();
      break;
    case 5:
        fifthScreen();
      break;
    case 6:
        sixthScreen();
      break;
    case 0:
      break;
    // BEGIN of the switch debouncing code
    int reading = digitalRead(buttonPin);
  if (reading != lastButtonState) {
    // reset the debouncing timer
    lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        hasChanged = true;
        WhichScreen++;
    } else {
      hasChanged = false;
  lastButtonState = reading;
  // END of the switch Debouncing code
  if (WhichScreen > 6){
    WhichScreen = 1;
void firstScreen()
   lcd.clear();
   lcd.setCursor(0,0); // Column, line
   lcd.print("This is screen 1");
   lcd.setCursor(0,1);
   lcd.print("On a menu system");
void secondScreen()
    lcd.clear();
    lcd.print("  Second screen");
    lcd.setCursor(0,1);
    lcd.print("of my menu !!");
void thirdScreen()
    lcd.clear();
    lcd.print("Hello, world!");
    lcd.setCursor(0,1);
    lcd.print("Third screen (3)");
void fourthScreen()
    lcd.clear();
    lcd.print("This is screen 4");
    lcd.setCursor(0,1);
    lcd.print("Just press btn");
void fifthScreen()
    lcd.clear();
    lcd.print("   Fifth screen");
    lcd.setCursor(0,1);
    lcd.print("i2C LCD screen");
void sixthScreen()
    lcd.clear();
    lcd.print("THE last screen");
    lcd.setCursor(0,1);
    lcd.print("  Sixth and last");
wifi den arduinoya seri data göndererek 2 adet motoru ileri geri kontrol etmem lazım.
LI200--sol motor ileri hız 200 şeklinde kodlar göndermek istiyorum
LG120 -- sol motor geri hız 120 şeklinde
RI080 --sag motor ileri hız 80
RG250 -- sağ motor geri hız 250
bu şekilde seriden data gönderiyorum ama bu kodları ayırıp analiz etme kısmını yapamadım
char buf;
buf = Serial.read();
burda buf değişkenini nasıl ayırabilirim
saygılar
Buf değişkeni seri porttan okunuyor
Merhaba arkadaşlar forumda yeni üyeyim arduino ile hobi amaçlı ilgileniyorum. Arduino ile kodlarımı güzelce çalıştırıyorum fakat tek sorun bunların bir bütün içinde çalıştıramıyorum. Yani 11 butonuna bastığımda o ses bitmeden 9 korna olarak girsin devreye ama 11 butonuna bastıktan sonra siren bittikten sonra korna giriyor. Birde hangi butona ne kadar basıyorsam o kadar çalsın istiyorum nasıl yapabilrim ?
KODLAR;
int buzz=10;
int siren=11;
int dat=9;
int kapat=12;
static unsigned long lastButtonTime = 0;
double angle_rad = PI/180.0;
double angle_deg = 180.0/PI;
void setup()
pinMode(10,OUTPUT);
pinMode(11,INPUT);
pinMode(9,INPUT);
pinMode(kapat,INPUT);
void loop()
butondurum12 = digitalRead(12);
if(((digitalRead(12))==(1 ))){
tone(10,50,125); // write to buzzer
delay(10);
if(((digitalRead(13))==(1 ))){
delay(10);
if(((digitalRead(11))==(1 ))){
// Whoop down
for(int hz = 1800; hz > 450; hz-=3){
tone(buzz, hz, 15);
delay(5);
for(int m=0;m<=5;m++)
digitalWrite(m,LOW);
digitalWrite(m,HIGH);
_loop();
void _delay(float seconds){
long endTime = millis() + seconds * 1000;
while(millis() < endTime)_loop();
Çok ilkelce ama mantıklı bir yol geldi aklıma 10 sn bekleyi 10 a bölüp her sn de düğmeyi kontrol edebilir
Hocam size zahmet kodlara ekleyebilirseniz ya da nasıl bir kod ekleyebileceğimi söyleyebilirseniz çok makbule geçer
Her koddan sonra if kullanarak butonu kontrol edip tonu çalabilirsiniz
if(((digitalRead(12))==(HIGH))){
for(int hz = 200; hz < 400; hz+=50){
tone(10,82,20); // write to buzzer
delay(20);
}else {
digitalWrite(12,LOW);
delay(350);
else komutu olan yeri ekledim istediğimi şuan yapıyorum ama 3 butondan gelen sesin bir tanesi böyle öteki seslerde bozulma oluyor. yani o seslere bu kodu eklemediğim halde tık tık yapıp bitiyor
Sadece if yapın eğer butona basılmadı ise direk döngüye devam eder
loran laran
