elmariacci
- 17 Şub 2012
- 14
- 1
- Yaş
- 35
arkadaşalar şu programda kesmelerde uyarı veriyor ve galiba bundan dolayi programi pic'e attiğimda çalişmiyor.nerede yanliş yapiyorum.
Kod:
#include "sw2.h"
#zero_ram
#ignore_warnings 203
unsigned long int display[10];
unsigned long int a,heart_rate;
#define LCD_EN PIN_B2
#define LCD_RS PIN_B1
#define LCD_D0 PIN_D3
#define LCD_D1 PIN_B3
#define LCD_D2 PIN_D2
#define LCD_D3 PIN_B4
#define ROLE PIN_B5
#include "lcd_mini.h"
#int_EXT
void EXT_isr(void)
unsigned long int b,c;
b=a;
c=a;
c=50000/c;
if((c<200) && (c>40)){
display[0]=display[1];
display[1]=display[2];
display[2]=display[3];
display[3]=display[4];
display[4]=display[5];
display[5]=display[6];
display[6]=display[7];
display[7]=display[8];
display[8]=display[9];
display[9]=40000/b;
heart_rate=(display[0]+display[1]+display[2]+display[3]+display[4]+display[5]+display[6]+display[7]+display[8]+display[9])/10;
printf(lcd_putc,"\1NABIZ=%3Lu A=%3Lu \2NABIZ OLCER",heart_rate,display[9]);
if(heart_rate>=120) output_high(ROLE); else output_low(ROLE);
a=0;
void main()
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_CLOCK_DIV_2);
setup_timer_0(RTCC_EXT_H_TO_L|RTCC_DIV_1);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_4,200,12);
setup_ccp1(CCP_OFF);
delay_ms(1000);
// input(PIN_A4);
lcd_init();
printf(lcd_putc,"\1NABIZ \2OLCER");
delay_ms(1000);
printf(lcd_putc,"\f");
enable_interrupts(INT_EXT);
enable_interrupts(GLOBAL);
while(1){
delay_ms(1);
a++;
// if(a>=3000){
// a=3000;
// output_high(ROLE);
// else
// output_low(ROLE);
Kod:
void lcd_delay(int data){
int i;
for(i=0; i<data; ++i);
void LCD_PulseEnable (){
output_high ( LCD_EN );
delay_ms(2);
output_low ( LCD_EN );
delay_ms(2);
void LCD_SetData (int cX ){
output_bit ( LCD_D0, cX & 0x01 );
output_bit ( LCD_D1, cX & 0x02 );
output_bit ( LCD_D2, cX & 0x04 );
output_bit ( LCD_D3, cX & 0x08 );
void lcd_adr ( int cX ){
LCD_SetData ( swap ( cX ) | 0x08 );
LCD_PulseEnable();
LCD_SetData ( swap ( cX ) );
LCD_PulseEnable();
void LCD_PutCmd ( int cX ){
LCD_PulseEnable();
LCD_PulseEnable();
void lcd_putc ( int cX ){
switch (cx) {
case '\f' : LCD_PutCmd ( 0x01 ); delay_ms(2); break;
case '\1' : lcd_adr( 0x00 ); delay_ms(2); break;
case '\2' : lcd_adr(0x40); delay_ms(2); break;
default :
output_high ( LCD_RS );
LCD_PulseEnable();
LCD_PulseEnable();
output_low ( LCD_RS );
void lcd_init (){
// output_low ( LCD_rw );
LCD_SetData ( 0x00 );
delay_ms ( 100 ); // wait enough time after Vdd rise
LCD_SetData ( 0x03 ); // init with specific nibbles to start 4-bit mode
LCD_PulseEnable ();
LCD_PulseEnable ();
LCD_PulseEnable ();
LCD_SetData ( 0x02 ); //* set 4-bit interface
LCD_PulseEnable (); //* send dual nibbles hereafter, MSN first
LCD_PutCmd ( 0x2C ); //* function set (all lines, 5x7 characters)
LCD_PutCmd ( 0x0C ); //* display ON, cursor off, no blink
LCD_PutCmd ( 0x01 ); //* clear display
LCD_PutCmd ( 0x06 ); //* entry mode set, increment & scroll left
void lcd_refresh(void){
LCD_PulseEnable ();
//LCD_PulseEnable ();
//LCD_PutCmd ( 0x01 ); //* clear display
void lcd_gotoxy(int8 x, int8 y){
if(y==1){
lcd_adr( 0x00+x-1 ); delay_ms(2);
}else{
lcd_adr( 0x40+x-1 ); delay_ms(2);
Kod:
>>>Warning 216 "sw2.c" Line 87(0,1): Interrupts disabled during call to prevent re-entrancy: (LCD_SetData)
>>>Warning 216 "sw2.c" Line 87(0,1): Interrupts disabled during call to prevent re-entrancy: (@delay_ms1)
>>>Warning 216 "sw2.c" Line 87(0,1): Interrupts disabled during call to prevent re-entrancy: (LCD_PulseEnable)
>>>Warning 216 "sw2.c" Line 87(0,1): Interrupts disabled during call to prevent re-entrancy: (lcd_putc)
