Cofaso 6,1 ( E - Plan 6,1 ) >Türkçe & Sorunlar Buraya !!!
mesut bey kontaktör güç kontaklarını bulamadım kodu nedir acaba bide start stop butonu yok
Start butonu = Norm IEC, Kod: S36
Stop butonu = Norm IEC, Kod: S32
Güç kontağını, Kod : S01 de ki, sembol ile oluşturacaksınız.
lütfen yardım.programı açamıyorum.error dosyasının içeriğini yapıştırıyorum aşağıya.
Kod:
Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space
at java.awt.image.PixelGrabber.setDimensions(Unknown Source)
	at sun.awt.image.OffScreenImageSource.produce(Unknown Source)
	at sun.awt.image.OffScreenImageSource.addConsumer(Unknown Source)
	at sun.awt.image.OffScreenImageSource.startProduction(Unknown Source)
	at java.awt.image.PixelGrabber.grabPixels(Unknown Source)
	at com.lowagie.text.Image.getInstance(Unknown Source)
	at com.lowagie.text.pdf.PdfGraphics2D.drawImage(Unknown Source)
	at scn.graph.GraphCanvas.drawImage(Unknown Source)
	at scn.graph.data.ImageObj.drawSelf(Unknown Source)
	at scn.graph.data.AbstractGraphObject.draw(Unknown Source)
	at eDraw.Symbol.VariantData.draw(Unknown Source)
	at eDraw.Symbol.GraphicsData.draw(Unknown Source)
	at eDraw.Symbol.Symbol.drawSelf(Unknown Source)
	at eDraw.Symbol.Symbol.draw(Unknown Source)
	at eDraw.View.eDrawView.onPaint(Unknown Source)
	at scn.graph.GraphView.paintGraph(Unknown Source)
	at eDraw.Pdf.PageToPdf.exportPageToPDF(Unknown Source)
	at eDraw.Print.PrintProject.doProjectPrint(Unknown Source)
	at eDraw.Menu.ProjectMenu.printProject(Unknown Source)
	at eDraw.Menu.ProjectMenu$10.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.AbstractButton.doClick(Unknown Source)
	at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
	at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at eDraw.Menu.PageMenu.exportPagePDF(Unknown Source)
	at eDraw.Menu.PageMenu$16.actionPerformed(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
Sembol seçim listesinde faz koruma rölesini sembolünü bulamadım yardımcı olurmusunuz
arkadaşlar sembol kütüphanesine ulaşmanın kısa yolu :
proje syfsında imleci boş alanda iken mouse sol tıklayıp sembol oluştur ikonunu sağ tık lıyoruz daha kolay
herkese kolay gelsin
mesut bey programda faz koruma rölesini bulamadım kodu verirmisiniz
Selam. Öncelikle böyle bir konu açtığınız için teşşekkür ederim. Benimde ilk başlarda sorunlarım oldu fakat şimdi programı kullanıyorum ve gayet güzel bir program. Fakat şöyle bir sorunum var: Projeyi hazırlayıp Sayfa listesi yaptığım zaman bütün sayfalar oluşuyor. Ançak Cihaz/PLC sayfası eksik oluşuyor. Proje içerisinde 5 adet cihaz kutusu kullanmama rağmen Cihaz/PLC listesinde 3 numaralı cihaz hiç gözükmüyor ve 4 numaralı olanın da sadece yarısı diğer sayfada gözüküyor. Yani 3 numaralı ile 4 numaranın ilk kısmının olduğu sayfa hiç gözükmüyor. Bunun sebebi ne olabilir.
Bu hatanın olası nedenleri ;
Program kurulumundan sonra bilgisayarınızı yeniden başlatın ve aşağıdaki işlemleri yapın :
1: C:\Program Files\cofaso 6.1\core dizinin'den StartMysql ulaşın ve çift tıklayın, tekrar deneyin.
2: Şifreyi yazarken büyük harf ile yazmadığınıza emin olun.
3: Sorununuz halen devam ediyorsa, programı kaldırın tekrar kurulumunu yapın.
4: Sorun düzelmezse 0212 676 52 48 numaradan ücretsiz teknik destek isteyiniz.
mesut hocam sorunum düzelmedi galiba yarışmaya katılamayacağım :(
1-1: C:\Program Files\cofaso 6.1\core dizinin'den StartMysql ulaşın ve çift tıklayın, tekrar deneyin.
3: Sorununuz halen devam ediyorsa, programı kaldırın tekrar kurulumunu yapın. demiştiniz....
buraya kadar olan işlemleri yapmama rağmen olmadı
son olarak bu akşam 4.önerinizi yapacağım ilginiz için teşekkür ederim.
faz koruma rölesini ve flaşör rölesinin kontağını bulamadım arkadaşlar yardımcı olurmusunuz...
Selam Serdalc arkadaşım faz koruma rolesi sembolü cofasoda yok onu sen ekliceksin yani fonksiyonel bi cihaz gibi gosterceksin, flasor roleninde sembol kodu (IEC O06)
kolay gelsin başarılar
saygılarımla...
Mert Bilgi İşlem'in [email protected] adresine projeyi XML olarak proje menüsü altından eksport edin ve sıkıştırarak (Zip veya 7z dosyası) gönderin.
Size cevap vereceklerdir.
__________________________
hakan 0785 için: Bu hata şayet bilgisayarınızın hafızası yeterli değilse oluşur.
parliament23için : Mert Bilgi İşlem'in [email protected] adresine projeyi XML olarak proje menüsü altından eksport edin ve sıkıştırarak (Zip veya 7z dosyası) gönderin.
yasin051
