aljasen
- 25 Haz 2009
- 2
- 1
- Yaş
- 39
slm arkadaslar bu forumda daha yeniyim.yapmak istedigim hani su kumanlarda varya mod lu sistem o,ra0 ve ra1 ucuna iki tane button bagladim ve bu butonlar benim iki tane mod button um. d portundakiler de normal sinyal gonderen butonlarim.normalde sinyal gonderebiliyorum ama su mod lu sistem i bi turlu yapamadim.
programim bole ugrastim ama bi turlu yapamadim.iki buton u bi turlu ayiramiyorum.yardimci olursaniz sevinirim.
Kod:
#include <16F877.h>
#include <string.h>
#FUSES NOWDT,NOPUT,NOPROTECT,BROWNOUT,NOLVP
#use delay(clock=4000000)
#use rs232(baud=300,parity=N,rcv = PIN_C7, XMIT = PIN_C6, bits=8, BRGH1OK )
#Byte PORTD = 8
#Byte PORTB = 8
#Byte PORTC = 8
#Byte PORTA = 3
char m1;
char m2;
#Bit e1 = PortA.0
#Bit e2 = PORTA.1
#Bit e3 = PortA.2
#Bit s1 = PortD.0
#Bit s2 = PORTD.1
#Bit s3 = PortD.2
#Bit s4 = PortD.3
#Bit s5 = PortD.4
#Bit s6 = PortD.5
#Bit s7 = PortD.6
#Bit s8 = PortD.7
void ilk();
void main()
ilk();
basla:
switch(true)
case e1==1:
if(s1==1) putc('a'); delay_ms(50);
if(s2==1) putc('b'); delay_ms(50);
if(s3==1) putc('c'); delay_ms(50);
if(s4==1) putc('d'); delay_ms(50);
if(s5==1) putc('e'); delay_ms(50);
if(s6==1) putc('f'); delay_ms(50);
if(s7==1) putc('g'); delay_ms(50);
if(s8==1) putc('h'); delay_ms(50);
break;
case e2==1:
if(s1==1) putc('t'); delay_ms(50);
break;
goto basla;
void ilk(){
Set_tris_B(0B00110010);
Set_Tris_D(0xff);
Set_Tris_C(0xff);
Set_Tris_A(0xff);
clear_interrupt(INT_RDA);
clear_interrupt(INT_EXT);
Disable_interrupts(GLOBAL);
PortD = 0b11111111;
PORTB = 0b11110010;
PORTC = 0b00000010;
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED,0,1);
setup_uart(True);
