HEX e çevirmede yardımcı olurmusunuz
Merhaba
Yazdığınız programı HEX'e dönüştürdüm problem yok.MPLAB 8.60 kullanıyorum.
Kod:
Release build of project `C:\Documents and Settings\Kudret Yahya Uzuner\Belgelerim\Untitled_6.disposable_mcp' started.
Language tool versions: MPASMWIN.exe v5.37, mplink.exe v4.37, mplib.exe v4.37
Thu Feb 17 19:02:15 2011
Clean: Deleting intermediary and output files.
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "Untitled_6.ASM" /l"Untitled_6.lst" /e"Untitled_6.err"
Warning[205] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 1 : Found directive in column 1. (LIST)
Warning[203] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 5 : Found opcode in column 1. (CLRF)
Warning[203] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 6 : Found opcode in column 1. (BSF)
Warning[203] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 7 : Found opcode in column 1. (CLRF)
Message[302] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 7 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Warning[203] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 8 : Found opcode in column 1. (BCF)
Warning[203] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 9 : Found opcode in column 1. (BSF)
Warning[205] C:\DOCUMENTS AND SETTINGS\KUDRET YAHYA UZUNER\BELGELERIM\UNTITLED_6.ASM 10 : Found directive in column 1. (END)
Executing: "C:\Program Files\Microchip\MPASM Suite\mplink.exe" /p16F628A "Untitled_6.o" /z__MPLAB_BUILD=1 /o"Untitled_6.cof" /M"Untitled_6.map" /W /x
MPLINK 4.37, Linker
Copyright (c) 1998-2010 Microchip Technology Inc.
Errors    : 0
Loaded C:\Documents and Settings\Kudret Yahya Uzuner\Belgelerim\Untitled_6.cof.
Release build of project `C:\Documents and Settings\Kudret Yahya Uzuner\Belgelerim\Untitled_6.disposable_mcp' succeeded.
Thu Feb 17 19:02:17 2011
BUILD SUCCEEDED
Merhaba
Clean: Done.
MPLINK 4.37, Linker
Errors : 0
BUILD SUCCEEDED
A.r.o sağol kudret,
hangi proğram hata vermiyor?
ilk yazdığım verici pro. mı yoksa sonrakı kısa proğram mı?
v8.63 ve v8.10 da denedim hala hata veriyor....
öyleyse benim pc de sorun var,
galiba vistada "mplab for windows" doğru çalışmıyor!
sen proje olarak kaydedip öyle mi çeviriyorsun yoksa direk mpasmden mi çeviriyorsun?
Merhaba
Kısa program hata vermiyor.Sizin ilk programınızda birçok hataları ayıkladım ama yine de yazılım ve bank'a geçiş hataları var.Zaman ayırıp yazılımı adım adım tekrar yazmak lazım.Amatör olduğum için biraz zorlanıyorum.
Kod:
Release build of project `M:\fatihnesli_asm\Untitled_3.disposable_mcp' started.
Fri Feb 18 14:24:32 2011
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPASMWIN.exe" /q /p16F628A "Untitled_3.ASM" /l"Untitled_3.lst" /e"Untitled_3.err"
Message[301] C:\PROGRAM FILES\MICROCHIP\MPASM SUITE\P16F628.INC 35 : MESSAGE: (Processor-header file mismatch.  Verify selected processor.)
Warning[205] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 3 : Found directive in column 1. (ORG)
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 14 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 16 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 18 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 20 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Error[113]   M:\FATIHNESLI_ASM\UNTITLED_3.ASM 60 : Symbol not previously defined (PORT)
Warning[207] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 67 : Found label after column 1. (R1CCVERISONU)
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 68 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Error[113]   M:\FATIHNESLI_ASM\UNTITLED_3.ASM 69 : Symbol not previously defined (R1CVERISONU)
Warning[207] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 75 : Found label after column 1. (R1BBVERISONU)
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 76 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Warning[207] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 83 : Found label after column 1. (R2CCVERISONU)
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 84 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Error[113]   M:\FATIHNESLI_ASM\UNTITLED_3.ASM 85 : Symbol not previously defined (R2CVERISONU)
Warning[207] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 91 : Found label after column 1. (R2BBVERISONU)
Message[302] M:\FATIHNESLI_ASM\UNTITLED_3.ASM 92 : Register in operand not in bank 0.  Ensure that bank bits are correct.
Halting build on first failure as requested.
Release build of project `M:\fatihnesli_asm\Untitled_3.disposable_mcp' failed.
Fri Feb 18 14:24:33 2011
BUILD FAILED
MPLAB-project-quick build hex dönüşür.
Forumda fazla yer işgal etmeyeyim.Tüm dosyanızı yolladım.Ancak bu kadarını yapabildim.Kolay gelsin.
öncelikle belirteyim, bu proğramı pic e yükledim , alıcı kısmıda yükledim ama devrem çalışmadı.(bu proğramı tavsiye etmiyorum)
bu yazılı değiştirdim, bu ödevimi bitirdiğimde faydalanmak isteyenlere sergileyeceğim inş.
2.olarakta bu hata olayını çözdüm
mslabwin penceresinde 2 değişiklik yapmam gerektiğini anladım
soldaki seçeneklerden "hexsadesimel" i , ortadaki seçeneklerdende "INHX3M" seçeneğini seçip uygun pic i de belirledikten sonra hex e çeviriliyor, bunları yapmadığım zaman 32hata veriyor. bu bilginin öğrenmek isteyenlere faydası olur inş.
hareket41
