picbasic ve assembler dili bilenler yardım pls
memoli195
18 Kas 2009
arkadaslar rfıd yazılımı buymuş ama bana picbasic seklınde lazım bilen arkadaslar bi cevirebilirmisinz ödev için cok lazım
#include <18F452.h>
#include <string.h>
#use delay(clock=4000000)
#define GLCD_WIDTH 128
#FUSES NOWDT //No Watch Dog Timer
#FUSES WDT128 //Watch Dog Timer uses 1:128 Postscale
#FUSES HS //High speed Osc (> 4mhz)
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOOSCSEN //Oscillator switching is disabled, main oscillator is source
#FUSES BROWNOUT //Reset when brownout detected
#FUSES BORV27 //Brownout reset at 2.7V
#FUSES NOPUT //No Power Up Timer
#FUSES STVREN //Stack full/underflow will cause reset
#FUSES NODEBUG //No Debug mode for ICD
#FUSES NOLVP //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT //Program memory not write protected
#FUSES NOWRTD //Data EEPROM not write protected
#FUSES NOWRTB //Boot block not write protected
#FUSES NOWRTC //configuration not registers write protected
#FUSES NOCPD //No EE protection
#FUSES NOCPB //No Boot Block code protection
#FUSES NOEBTR //Memory not protected from table reads
#FUSES NOEBTRB //Boot block not protected from table reads
#FUSES CCP2B3 //önemli!!!!
//------------{LCD için pin değişiklikleri yapılıyor}-------------------
#define GLCD_CS1 PIN_E0
#define GLCD_CS2 PIN_E1
#define GLCD_RST PIN_C3
#define GLCD_DI PIN_C1
#include "HDM64GS12.c"
#include "graphics.c"
#include <em4095.c>
#include <em4102.c>
#use fast_io(A)
char text[] = "RFID SISTEMI";
char text2[] = "Microchip PIC";
int8 wrong_attemps;
int32 tagNum;
int8 customerCode;
int8 msg[32];
int8 kodum[32];
int8 code[5];
void main()
SET_TRIS_A( 0x00 );
setup_adc_ports (RA0_ANALOG);
setup_adc (ADC_OFF);
set_adc_channel (0);
setup_psp (PSP_DISABLED);
SETUP_SPI (SPI_MASTER|SPI_CLK_DIV_16|SPI_H_TO_L|SPI_XMIT_L_TO_H);
setup_wdt (WDT_OFF);
setup_timer_0 (RTCC_INTERNAL);
setup_timer_1 (T1_INTERNAL|T1_DIV_BY_1);
setup_timer_2 (T2_DISABLED, 0, 1);
setup_timer_2 (T2_DIV_BY_4, 255, 4);
setup_timer_3 (T3_DISABLED|T3_DIV_BY_1);
disable_interrupts (GLOBAL);
rf_init(); //rfid yüklemesini yap
rf_powerUp(); //modülü çalıştır
wrong_attemps = 0;
glcd_init (ON);
while (1)
if(read_4102(code)) //kart antene yapkaştırılınca
tagNum = make32(code[1],code[2],code[3],code[4]);
customerCode = code[0];
sprintf(kodum,"\r\nOkunan ID: %u-%lu",customerCode,tagNum);
glcd_fillScreen (0); //ekranı sil
glcd_text57 (10, 24, kodum, 1, ON) ; //yeni kodu ekrana yaz
arkadaşım C dili bilen varmı diye açacaksın başlığı
include görünce asm
if görünce basic mi sandın..?
C dilidir bu ayrıca rfid için program yazıp okumaktan fazlasını bilmen gerekir
Bu C kodunu bu haliyle hiçbir şeye çeviremezsiniz çünkü
"HDM64GS12.c"
"graphics.c"
<em4095.c>
<em4102.c>
dosyalarında yer alan fonksiyonlar çağrılıyor.Bu dosyalar mevcut durumlarıyla asm ya da basic'te yazılacak programa include edilemezler, bu durumda ya yeni include dosyaları hazırlanacak ya da bunlardan çağrılan fonksiyonlar asm ya da basic kodunun içine yazılacak. Kısacası, uzun iş.
uds12
