"plc data type" veya plc data türleri
ikavakci
16 Nis 2008
arkadaşlar;
genelde gördüğüm bir eksik var.
plc data type veya plc data türleri konusunda eksiklerimiz var
Bu nedenle bu konuyu açmaya kara verdim.
1- "data types" veya data türleri
aşağıdaki tablodan sormak istediğiniz herşeyi anlatabilirim.
Type and
Description
Size
in
Bits
Format OptionsRange and Number Notation
(lowest to highest values)
Example in STL
BOOL (Bit)1Boolean text TRUE/FALSE TRUE
BYTE (Byte)8Hexadecimal numberB#16#0 to B#16#FF L B#16#10
L byte#16#10
WORD (Word)16Binary number2#0 to 2#1111_1111_1111_1111L 2#0001_0000_0000_0000
Hexadecimal numberW#16#0 to W#16#FFFFL W#16#1000
L word#16#1000
BCDC#0 to C#999L C#998
Decimal number unsignedB#(0,0) to B#(255,255)L B#(10,20)
L byte#(10,20)
DWORD (Double word)32Binary number2#0 to 2#1111_1111_1111_1111_
1111_1111_1111_1111
L 2#1000_0001_0001_1000_
1011_1011_0111_1111
Hexadecimal numberW#16#0000_0000 to W#16#FFFF_FFFFL DW#16#00A2_1234
L dword#16#00A2_1234
Decimal number unsignedB#(0,0,0,0) to B#(255,255,255,255)L B#(1, 14, 100, 120)
L byte#(1,14,100,120)
INT (Integer)16Decimal number signed-32768 to 32767L 101
DINT (Double integer)32Decimal number signedL#-2147483648 to L#2147483647L L#101
REAL (Floating-point number)32IEEE Floating-point numberUpper limit +/-3.402823e+38
Lower limit +/-1.175495e-38
L 1.234567e+13
S5TIME (SIMATIC time)16S7 time in steps of 10ms (default)S5T#0H_0M_0S_10MS to
S5T#2H_46M_30S_0MS and
S5T#0H_0M_0S_0MS
L S5T#0H_1M_0S_0MS
L S5TIME#0H_1H_1M_0S_0MS
TIME (IEC time)32IEC time in steps of 1 ms, integer signedT#24D_20H_31M_23S_648MS
to
T#24D_20H_31M_23S_647MS
L T#0D_1H_1M_0S_0MS
L TIME#0D_1H_1M_0S_0MS
DATE (IEC date)16IEC date in steps of 1 dayD#1990-1-1 to
D#2168-12-31
L D#1996-3-15
L DATE#1996-3-15
TIME _OF_DAY (Time)32Time in steps of 1 msTOD#0:0:0.0 to
TOD#23:59:59.999
L TOD#1:10:3.3
L TIME_OF_DAY#1:10:3.3
CHAR (Character)8ASCII charactersA', 'B' etc.L 'E'
hardware kısmından sinyal kontrolu için girdiğimde bilgisayara format atmadan önce "bool" -"true,false" olarak görüyordum
sonra "bit"-"2#0,2#1" olarak karşıma çıkıyor...bu sekilde değişmesinin sebebi nedir?tamam bir farkı yok belki ama ne oldugunu öğrenmek istiyorum
sayın rotsis
bilgisayar konusunda tam emin değilim ama;
format öncesi;
data görüntüleme sistemi "boolan" şeklinde
true ve false
format sonrası;
data görüntüleme sistemi "binary number" şekline dönmüştür.
2#0 veya 2#1
söylediğiniz gibi 2 gösterimde aynı şey
fakat pc'de data görüntülemenin nereden değiştirildiğini bilmiyorum.
önemli ise araştırırım.
yok hayır çok önemli değil lakin farklı bir sürüm mü yükledim diye düşündüm birden.yine de teşekkürler
dostum decimal sayıyı s5time nasıl cevirmeliyim panelden girdiğim degeri dakika cinsinden zamanlama yapmam lazım
erenadem_25
