PTC Pro Engineer Wildfire 5.0 F000 x86 iso
serdalyen
28 Tem 2007
PTC Pro Engineer Wildfire 5.0 F000 x86 - ISO | 3.53GB
SAD / CAM / CAE System American company PTC (Parametric Technology Corporation) is a CAD system of the upper level and covers all areas of design, technological preparation of production and manufacturing. Wide range of three-dimensional modeling apparatus, the high quality of the result and its stability to subsequent changes made by the system of Pro / ENGINEER by one of the leaders in CAD / CAM / CAE-systems, and have direct access to the system life cycle support product Windchill PDMLink translates Pro / ENGINEER WILDFIRE the category of PLM-systems.
New features:
- Working with large assemblies: reduction to 40% of the volume occupied by the memory, the use of multi-thread in the CPU and the consequent reduction in the time of the upgrade in large assemblies.
- Associative Interface MCAD-ECAD.
- Selective dynamic change of data (technology IDX).
- Simulation of ribbon cables: a new menu for new objects: parameters of the ribbon cable when modeling in 3D, «crook", "kink", "pass through"; decomposition of the cable within a single ribbon cable, alignment and binding tape along the cable laying.
- Export diagrams of Pro / ENGINEER (Pro / DIAGRAM) in the RSD: export to a neutral format: Connectors, conductors, cables, labels, tables, layers, etc.
- 3D-annotation of drawings.
- Automated rounding edges (Auto-Round).
- New ability to remove surface when designing injection molds; simplify the geometry by removing small and insignificant elements of the model.
- Import Data Doctor - a new mechanism to facilitate fuller use of models and data from external CAD.
- Direct editing of surfaces: control points editing the history of editing, support for multiple editing sessions on the same parts of complex shape.
- Rendering: HDRI (High Dynamic Range Imaging) function for the light, reflection and background, the dynamic deployment of textures, rendering the zones ( "regional" rendering); space filling (picture room ").
- Reverse Engineering: better graphics and better performance, automatic identification of "holes" in the facet model; offset facet model; symmetrical building / pruning model.
- Инженерный анализ: новый механизм отслеживания и диагностики ошибок в Mechanica, управление генерацией МКЭ-сетки; оптимизация памяти и ресурсов ЦПУ; нелинейный анализ; импорт данных из пакетов CFD.
- Machining on CNC machines: The new user interface, manager of the processing, management and repositioning of the challenge-supply of the instrument; improve finishing operations, the direct implementation of NURBS surfaces; elaboration of the corners and pockets, simulation of kinematics machine tool, support for scanning in the Pro / CMM.
- Import / Export (Data Exchange Processor): Interface UG, support for layers in NX3 and NX4; interface to PDF, support for U3D and 3D model Image; interface with AutoCAD: support for AutoCAD 2005/2006; interface ProductView; interface JT: Import / export of parts and assemblies, simplified view.
OS: WinAll
Language: English
linkler kaldırıldı
Dosya, Dosya Paylaşım Sitesinden Silindiği İçin Konu Çöpe Taşınmıştır.
ceyranci_hy
