Sieg C6 CNC çevrim projesi
Geç, göreceksin bırakamayacaksın. Solidi açmıyorum artık. Hantal program. Şu post processorun güzelliğine gel..
Kod:
  Copyright (C) 2012-2017 by Autodesk, Inc.
  All rights reserved.
  Mach3 Lathe post processor configuration.
  $Revision: 41601 2e6200651f01fad70bd72491303b9729cd57fc6e $
  $Date: 2017-09-14 12:02:56 $
  FORKID {506EED9A-A4C0-40D3-BC83-CEC4CE91AAEA}
description = "Mach3 Turning";
vendor = "Artsoft";
vendorUrl = "http://www.machsupport.com";
legal = "Copyright (C) 2012-2017 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 24000;
longDescription = "Generic turning post for Mach3.";
extension = "nc";
programNameIsInteger = false;
setCodePage("ascii");
capabilities = CAPABILITY_TURNING;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.01, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(180);
allowHelicalMoves = true;
allowedCircularPlanes = undefined; // allow any circular motion
// user-defined properties
properties = {
  writeMachine: false, // write machine
  preloadTool: false, // preloads next tool on tool change if any
  showSequenceNumbers: true, // show sequence numbers
  sequenceNumberStart: 10, // first sequence number
  sequenceNumberIncrement: 1, // increment for sequence numbers
  optionalStop: true, // optional stop
  separateWordsWithSpace: true, // specifies that the words should be separated with a white space
  useRadius: false, // specifies that arcs should be output using the radius (R word) instead of the I, J, and K words.
  maximumSpindleSpeed: 4000, // specifies the maximum spindle speed
  useParametricFeed: false, // specifies that feed should be output using Q values
  showNotes: false, // specifies that operation notes should be output.
  g53HomePositionX: 0, // home position for X-axis
  g53HomePositionZ: 0 // home position for Z-axis
// user-defined property definitions
propertyDefinitions = {
  writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
  preloadTool: {title:"Preload tool", description:"Preloads the next tool at a tool change (if any).", type:"boolean"},
  showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
  sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
  sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
  optionalStop: {title:"Optional stop", description:"Outputs optional stop code during when necessary in the code.", type:"boolean"},
  separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
  useRadius: {title:"Radius arcs", description:"If yes is selected, arcs are outputted using radius values rather than IJK.", type:"boolean"},
  maximumSpindleSpeed: {title:"Max spindle speed", description:"Defines the maximum spindle speed allowed by your machines.", type:"integer", range:[0, 999999999]},
  useParametricFeed:  {title:"Parametric feed", description:"Specifies the feed value that should be output using a Q value.", type:"boolean"},
  showNotes: {title:"Show notes", description:"Writes operation notes as comments in the outputted code.", type:"boolean"},
  g53HomePositionX: {title:"G53 home position X", description:"G53 X-axis home position.", type:"number"},
  g53HomePositionZ: {title:"G53 home position Z", description:"G53 Z-axis home position.", type:"number"}
var permittedCommentChars = " ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.,=_-";
var gFormat = createFormat({prefix:"G", decimals:1});
var mFormat = createFormat({prefix:"M", decimals:1});
var spatialFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var xFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true, scale:2}); // diameter mode
var yFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var zFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var rFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true}); // radius
var feedFormat = createFormat({decimals:(unit == MM ? 4 : 5), forceDecimal:true});
var pitchFormat = createFormat({decimals:6, forceDecimal:true});
var toolFormat = createFormat({decimals:0, width:4, zeropad:true});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-99999.999
var milliFormat = createFormat({decimals:0}); // milliseconds // range 1-9999
var taperFormat = createFormat({decimals:1, scale:DEG});
var xOutput = createVariable({prefix:"X"}, xFormat);
var yOutput = createVariable({prefix:"Y"}, yFormat);
var zOutput = createVariable({prefix:"Z"}, zFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var pitchOutput = createVariable({prefix:"F", force:true}, pitchFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I"}, spatialFormat); // no scaling
var jOutput = createReferenceVariable({prefix:"J"}, spatialFormat);
var kOutput = createReferenceVariable({prefix:"K"}, spatialFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91 // only for B and C mode
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G98-99 / G94-95
var gSpindleModeModal = createModal({}, gFormat); // modal group 5 // G96-97
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-21
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
// fixed settings
var firstFeedParameter = 500;
var gotSecondarySpindle = true;
var gotTailStock = false;
var WARNING_WORK_OFFSET = 0;
// collected state
var sequenceNumber;
var currentWorkOffset;
var optionalSection = false;
var forceSpindleSpeed = false;
var activeMovements; // do not use by default
var currentFeedId;
function getCode(code) {
  switch(code) {
  // case "PART_CATCHER_ON":
    // return mFormat.format(SPECIFY YOUR CODE HERE);
  // case "PART_CATCHER_OFF":
  // case "TAILSTOCK_ON":
  // case "TAILSTOCK_OFF":
  // case "ENGAGE_C_AXIS":
    // machineState.cAxisIsEngaged = true;
    // return cAxisEngageModal.format(UNSUPPORTED);
  // case "DISENGAGE_C_AXIS":
    // machineState.cAxisIsEngaged = false;
  // case "POLAR_INTERPOLATION_ON":
    // return gPolarModal.format(UNSUPPORTED);
  // case "POLAR_INTERPOLATION_OFF":
  // case "STOP_LIVE_TOOL":
    // machineState.liveToolIsActive = false;
    // return mFormat.format(UNSUPPORTED);
  // case "STOP_MAIN_SPINDLE":
    // machineState.mainSpindleIsActive = false;
  // case "STOP_SUB_SPINDLE":
    // machineState.subSpindleIsActive = false;
  // case "START_LIVE_TOOL_CW":
    // machineState.liveToolIsActive = true;
  // case "START_LIVE_TOOL_CCW":
  case "START_MAIN_SPINDLE_CW":
    // machineState.mainSpindleIsActive = true;
    return mFormat.format(3);
  case "START_MAIN_SPINDLE_CCW":
    return mFormat.format(4);
  // case "START_SUB_SPINDLE_CW":
    // machineState.subSpindleIsActive = true;
  // case "START_SUB_SPINDLE_CCW":
  // case "MAIN_SPINDLE_BRAKE_ON":
    // machineState.mainSpindleBrakeIsActive = true;
    // return cAxisBrakeModal.format(UNSUPPORTED);
  // case "MAIN_SPINDLE_BRAKE_OFF":
    // machineState.mainSpindleBrakeIsActive = false;
  // case "SUB_SPINDLE_BRAKE_ON":
    // machineState.subSpindleBrakeIsActive = true;
  // case "SUB_SPINDLE_BRAKE_OFF":
    // machineState.subSpindleBrakeIsActive = false;
  case "FEED_MODE_UNIT_REV":
    return gFeedModeModal.format(95);
  case "FEED_MODE_UNIT_MIN":
    return gFeedModeModal.format(94);
  case "CONSTANT_SURFACE_SPEED_ON":
    return gSpindleModeModal.format(96);
  case "CONSTANT_SURFACE_SPEED_OFF":
    return gSpindleModeModal.format(97);
  // case "MAINSPINDLE_AIR_BLAST_ON":
  // case "MAINSPINDLE_AIR_BLAST_OFF":
  // case "SUBSPINDLE_AIR_BLAST_ON":
  // case "SUBSPINDLE_AIR_BLAST_OFF":
  // case "CLAMP_PRIMARY_CHUCK":
  // case "UNCLAMP_PRIMARY_CHUCK":
  // case "CLAMP_SECONDARY_CHUCK":
  // case "UNCLAMP_SECONDARY_CHUCK":
  // case "SPINDLE_SYNCHRONIZATION_ON":
    // machineState.spindleSynchronizationIsActive = true;
    // return gSynchronizedSpindleModal.format(UNSUPPORTED);
  // case "SPINDLE_SYNCHRONIZATION_OFF":
    // machineState.spindleSynchronizationIsActive = false;
  // case "START_CHIP_TRANSPORT":
  // case "STOP_CHIP_TRANSPORT":
  // case "OPEN_DOOR":
  // case "CLOSE_DOOR":
  case "COOLANT_FLOOD_ON":
    return mFormat.format(8);
  case "COOLANT_FLOOD_OFF":
    return mFormat.format(9);
  // case "COOLANT_AIR_ON":
  // case "COOLANT_AIR_OFF":
  case "COOLANT_THROUGH_TOOL_ON":
    return mFormat.format(88);
  case "COOLANT_THROUGH_TOOL_OFF":
    return mFormat.format(89);
  case "COOLANT_OFF":
  default:
    error(localize("Command " + code + " is not defined."));
    return 0;
  Writes the specified block.
function writeBlock() {
  if (properties.showSequenceNumbers) {
    if (optionalSection) {
      var text = formatWords(arguments);
      if (text) {
        writeWords("/", "N" + sequenceNumber, text);
    } else {
      writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += properties.sequenceNumberIncrement;
  } else {
      writeWords2("/", arguments);
    } else {
      writeWords(arguments);
  Writes the specified optional block.
function writeOptionalBlock() {
    var words = formatWords(arguments);
    if (words) {
      writeWords("/", "N" + sequenceNumber, words);
  } else {
function formatComment(text) {
  return "(" + filterText(String(text).toUpperCase(), permittedCommentChars).replace(/[\(\)]/g, "") + ")";
  Output a comment.
function writeComment(text) {
  writeln(formatComment(text));
function onOpen() {
  if (properties.useRadius) {
    maximumCircularSweep = toRad(90); // avoid potential center calculation errors for CNC
  yOutput.disable();
  if (!properties.separateWordsWithSpace) {
    setWordSeparator("");
  sequenceNumber = properties.sequenceNumberStart;
  writeln("%");
  if (programName) {
    writeComment(filterText(String(programName).toUpperCase(), permittedCommentChars));
  if (programComment) {
    writeComment(filterText(String(programComment).toUpperCase(), permittedCommentChars));
  // dump machine configuration
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (properties.writeMachine && (vendor || model || description)) {
    writeComment(localize("Machine"));
    if (vendor) {
      writeComment("  " + localize("vendor") + ": " + vendor);
    if (model) {
      writeComment("  " + localize("model") + ": " + model);
    if (description) {
      writeComment("  " + localize("description") + ": "  + description);
  if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
    for (var i = 0; i < getNumberOfSections(); ++i) {
      if (getSection(i).workOffset > 0) {
        error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
        return;
  // absolute coordinates and feed per min
  writeBlock(gAbsIncModal.format(90), getCode("FEED_MODE_UNIT_MIN"), gPlaneModal.format(18));
  switch (unit) {
  case IN:
    writeBlock(gUnitModal.format(20));
    break;
  case MM:
    writeBlock(gUnitModal.format(21));
    break;
  // writeBlock(gFormat.format(50), sOutput.format(properties.maximumSpindleSpeed));
  onCommand(COMMAND_START_CHIP_TRANSPORT);
function onComment(message) {
  writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
function forceFeed() {
  currentFeedId = undefined;
  feedOutput.reset();
/** Force output of X, Y, Z, and F on next output. */
function forceAny() {
  forceXYZ();
  forceFeed();
function FeedContext(id, description, feed) {
  this.id = id;
  this.description = description;
  this.feed = feed;
function getFeed(f) {
  if (activeMovements) {
    var feedContext = activeMovements[movement];
    if (feedContext != undefined) {
      if (!feedFormat.areDifferent(feedContext.feed, f)) {
        if (feedContext.id == currentFeedId) {
          return ""; // nothing has changed
        forceFeed();
        currentFeedId = feedContext.id;
        return "F#" + (firstFeedParameter + feedContext.id);
    currentFeedId = undefined; // force Q feed next time
  return feedOutput.format(f); // use feed value
function initializeActiveFeeds() {
  activeMovements = new Array();
  var movements = currentSection.getMovements();
  var feedPerRev = currentSection.feedMode == FEED_PER_REVOLUTION;
  var id = 0;
  var activeFeeds = new Array();
  if (hasParameter("operation:tool_feedCutting")) {
    if (movements & ((1 << MOVEMENT_CUTTING) | (1 << MOVEMENT_LINK_TRANSITION) | (1 << MOVEMENT_EXTENDED))) {
      var feedContext = new FeedContext(id, localize("Cutting"), feedPerRev ? getParameter("operation:tool_feedCuttingRel") : getParameter("operation:tool_feedCutting"));
      activeFeeds.push(feedContext);
      activeMovements[MOVEMENT_CUTTING] = feedContext;
      activeMovements[MOVEMENT_LINK_TRANSITION] = feedContext;
      activeMovements[MOVEMENT_EXTENDED] = feedContext;
    ++id;
    if (movements & (1 << MOVEMENT_PREDRILL)) {
      feedContext = new FeedContext(id, localize("Predrilling"), feedPerRev ? getParameter("operation:tool_feedCuttingRel") : getParameter("operation:tool_feedCutting"));
      activeMovements[MOVEMENT_PREDRILL] = feedContext;
    ++id;
  if (hasParameter("operation:finishFeedrate")) {
    if (movements & (1 << MOVEMENT_FINISH_CUTTING)) {
      var finishFeedrateRel;
      if (hasParameter("operation:finishFeedrateRel")) {
        finishFeedrateRel = getParameter("operation:finishFeedrateRel");
      } else if (hasParameter("operation:finishFeedratePerRevolution")) {
        finishFeedrateRel = getParameter("operation:finishFeedratePerRevolution");
      var feedContext = new FeedContext(id, localize("Finish"), feedPerRev ? finishFeedrateRel : getParameter("operation:finishFeedrate"));
      activeMovements[MOVEMENT_FINISH_CUTTING] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting")) {
      var feedContext = new FeedContext(id, localize("Finish"), feedPerRev ? getParameter("operation:tool_feedCuttingRel") : getParameter("operation:tool_feedCutting"));
    ++id;
  if (hasParameter("operation:tool_feedEntry")) {
    if (movements & (1 << MOVEMENT_LEAD_IN)) {
      var feedContext = new FeedContext(id, localize("Entry"), feedPerRev ? getParameter("operation:tool_feedEntryRel") : getParameter("operation:tool_feedEntry"));
      activeMovements[MOVEMENT_LEAD_IN] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedExit")) {
    if (movements & (1 << MOVEMENT_LEAD_OUT)) {
      var feedContext = new FeedContext(id, localize("Exit"), feedPerRev ? getParameter("operation:tool_feedExitRel") : getParameter("operation:tool_feedExit"));
      activeMovements[MOVEMENT_LEAD_OUT] = feedContext;
    ++id;
  if (hasParameter("operation:noEngagementFeedrate")) {
    if (movements & (1 << MOVEMENT_LINK_DIRECT)) {
      var feedContext = new FeedContext(id, localize("Direct"), feedPerRev ? getParameter("operation:noEngagementFeedrateRel") : getParameter("operation:noEngagementFeedrate"));
      activeMovements[MOVEMENT_LINK_DIRECT] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting") &&
             hasParameter("operation:tool_feedEntry") &&
        id,
        localize("Direct"),
        Math.max(
          feedPerRev ? getParameter("operation:tool_feedCuttingRel") : getParameter("operation:tool_feedCutting"),
          feedPerRev ? getParameter("operation:tool_feedEntryRel") : getParameter("operation:tool_feedEntry"),
    ++id;
  if (hasParameter("operation:reducedFeedrate")) {
    if (movements & (1 << MOVEMENT_REDUCED)) {
      var feedContext = new FeedContext(id, localize("Reduced"), feedPerRev ? getParameter("operation:reducedFeedrateRel") : getParameter("operation:reducedFeedrate"));
      activeMovements[MOVEMENT_REDUCED] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedRamp")) {
    if (movements & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_HELIX) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_ZIG_ZAG))) {
      var feedContext = new FeedContext(id, localize("Ramping"), feedPerRev ? getParameter("operation:tool_feedRampRel") : getParameter("operation:tool_feedRamp"));
      activeMovements[MOVEMENT_RAMP] = feedContext;
      activeMovements[MOVEMENT_RAMP_HELIX] = feedContext;
      activeMovements[MOVEMENT_RAMP_PROFILE] = feedContext;
      activeMovements[MOVEMENT_RAMP_ZIG_ZAG] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedPlunge")) {
    if (movements & (1 << MOVEMENT_PLUNGE)) {
      var feedContext = new FeedContext(id, localize("Plunge"), feedPerRev ? getParameter("operation:tool_feedPlungeRel") : getParameter("operation:tool_feedPlunge"));
      activeMovements[MOVEMENT_PLUNGE] = feedContext;
    ++id;
  if (true) { // high feed
    if (movements & (1 << MOVEMENT_HIGH_FEED)) {
      var feedContext = new FeedContext(id, localize("High Feed"), this.highFeedrate);
      activeMovements[MOVEMENT_HIGH_FEED] = feedContext;
    ++id;
  for (var i = 0; i < activeFeeds.length; ++i) {
    var feedContext = activeFeeds[i];
    writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
function getSpindle() {
  if (getNumberOfSections() == 0) {
    return SPINDLE_PRIMARY;
  if (getCurrentSectionId() < 0) {
    return getSection(getNumberOfSections() - 1).spindle == 0;
  if (currentSection.getType() == TYPE_TURNING) {
    return currentSection.spindle;
  } else {
    if (isSameDirection(currentSection.workPlane.forward, new Vector(0, 0, 1))) {
    } else if (isSameDirection(currentSection.workPlane.forward, new Vector(0, 0, -1))) {
      if (!gotSecondarySpindle) {
        error(localize("Secondary spindle is not available."));
      return SPINDLE_SECONDARY;
    } else {
function onSection() {
  if (currentSection.getType() != TYPE_TURNING) {
    if (!hasParameter("operation-strategy") || (getParameter("operation-strategy") != "drill")) {
      if (currentSection.getType() == TYPE_MILLING) {
        error(localize("Milling toolpath is not supported."));
      } else {
        error(localize("Non-turning toolpath is not supported."));
      return;
  var forceToolAndRetract = optionalSection && !currentSection.isOptional();
  optionalSection = currentSection.isOptional();
  var turning = (currentSection.getType() == TYPE_TURNING);
  var insertToolCall = forceToolAndRetract || isFirstSection() ||
    currentSection.getForceToolChange && currentSection.getForceToolChange() ||
    (tool.number != getPreviousSection().getTool().number);
  var retracted = false; // specifies that the tool has been retracted to the safe plane
  var newSpindle = isFirstSection() ||
    (getPreviousSection().spindle != currentSection.spindle);
  var newWorkOffset = isFirstSection() ||
    (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
  if (insertToolCall || newSpindle || newWorkOffset) {
    // retract to safe plane
    retracted = true;
    if (!isFirstSection() && insertToolCall) {
      onCommand(COMMAND_COOLANT_OFF);
    writeBlock(gAbsIncModal.format(91), gFormat.format(28), "X" + xFormat.format(0)); // retract
    writeBlock(gAbsIncModal.format(90));
    forceXYZ();
  writeln("");
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
      writeComment(comment);
  if (properties.showNotes && hasParameter("notes")) {
    var notes = getParameter("notes");
    if (notes) {
      var lines = String(notes).split("\n");
      var r1 = new RegExp("^[\\s]+", "g");
      var r2 = new RegExp("[\\s]+$", "g");
      for (line in lines) {
        var comment = lines[line].replace(r1, "").replace(r2, "");
        if (comment) {
  if (insertToolCall) {
    retracted = true;
    // onCommand(COMMAND_COOLANT_OFF);
    if (!isFirstSection() && properties.optionalStop) {
      onCommand(COMMAND_OPTIONAL_STOP);
    if (tool.number > 99) {
      warning(localize("Tool number exceeds maximum value."));
    var compensationOffset = tool.isTurningTool() ? tool.compensationOffset : tool.lengthOffset;
    if (compensationOffset > 99) {
      error(localize("Compensation offset is out of range."));
      return;
    writeBlock("T" + toolFormat.format(tool.number * 100 + compensationOffset));
    if (tool.comment) {
      writeComment(tool.comment);
    if (properties.preloadTool) {
      var nextTool = getNextTool(tool.number);
      if (nextTool) {
        var compensationOffset = nextTool.isTurningTool() ? nextTool.compensationOffset : nextTool.lengthOffset;
          return;
        writeBlock("T" + toolFormat.format(nextTool.number * 100 + compensationOffset));
      } else {
        // preload first tool
        var section = getSection(0);
        var firstTool = section.getTool().number;
        if (tool.number != firstTool.number) {
          var compensationOffset = firstTool.isTurningTool() ? firstTool.compensationOffset : firstTool.lengthOffset;
            return;
          writeBlock("T" + toolFormat.format(firstTool.number * 100 + compensationOffset));
  // wcs
  if (insertToolCall) { // force work offset when changing tool
    currentWorkOffset = undefined;
  var workOffset = currentSection.workOffset;
  if (workOffset == 0) {
    warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
    workOffset = 1;
  if (workOffset > 0) {
    if (workOffset > 6) {
      var p = workOffset - 6; // 1->...
      if (p > 300) {
        error(localize("Work offset out of range."));
        return;
      } else {
        if (workOffset != currentWorkOffset) {
          writeBlock(gFormat.format(54.1), "P" + p); // G54.1P
          currentWorkOffset = workOffset;
    } else {
        writeBlock(gFormat.format(53 + workOffset)); // G54->G59
  // set coolant after we have positioned at Z
  setCoolant(tool.coolant);
  forceAny();
  gFeedModeModal.reset();
  if (currentSection.feedMode == FEED_PER_REVOLUTION) {
    writeBlock(getCode("FEED_MODE_UNIT_REV"));
  } else {
    writeBlock(getCode("FEED_MODE_UNIT_MIN"));
  if (gotTailStock) {
    writeBlock(getCode(currentSection.tailstock ? "TAILSTOCK_ON" : "TAILSTOCK_OFF"));
  // writeBlock(mFormat.format(clampPrimaryChuck ? x : x));
  // writeBlock(mFormat.format(clampSecondaryChuck ? x : x));
  var mSpindle = getCode(tool.clockwise ? "START_MAIN_SPINDLE_CW" : "START_MAIN_SPINDLE_CCW");
  gSpindleModeModal.reset();
  if (currentSection.getTool().getSpindleMode() == SPINDLE_CONSTANT_SURFACE_SPEED) {
    var maximumSpindleSpeed = (tool.maximumSpindleSpeed > 0) ? Math.min(tool.maximumSpindleSpeed, properties.maximumSpindleSpeed) : properties.maximumSpindleSpeed;
    writeBlock(gFormat.format(48), sOutput.format(maximumSpindleSpeed));
    writeBlock(getCode("CONSTANT_SURFACE_SPEED_ON"), sOutput.format(tool.surfaceSpeed * ((unit == MM) ? 1/1000.0 : 1/12.0)), mSpindle);
  } else {
    writeBlock(getCode("CONSTANT_SURFACE_SPEED_OFF"), sOutput.format(tool.spindleRPM), mSpindle);
  setRotation(currentSection.workPlane);
  var initialPosition = getFramePosition(currentSection.getInitialPosition());
  if (!retracted) {
    // TAG: need to retract along X or Z
    if (getCurrentPosition().z < initialPosition.z) {
      writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
    writeBlock(
      gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y), zOutput.format(initialPosition.z)
  if (currentSection.partCatcher) {
    engagePartCatcher(true);
  if (properties.useParametricFeed &&
      hasParameter("operation-strategy") &&
      (getParameter("operation-strategy") != "drill") && // legacy
      !(currentSection.hasAnyCycle && currentSection.hasAnyCycle())) {
    if (!insertToolCall &&
        activeMovements &&
        (getCurrentSectionId() > 0) &&
        (getPreviousSection().getPatternId() == currentSection.getPatternId()) && (currentSection.getPatternId() != 0)) {
      // use the current feeds
    } else {
      initializeActiveFeeds();
  } else {
    activeMovements = undefined;
  if (insertToolCall || retracted) {
    gPlaneModal.reset();
function onDwell(seconds) {
  if (seconds > 99999.999) {
    warning(localize("Dwelling time is out of range."));
  seconds = clamp(0, seconds, 99999999);
  writeBlock(/*gFeedModeModal.format(94),*/ gFormat.format(4), "P" + secFormat.format(seconds));
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
  pendingRadiusCompensation = radiusCompensation;
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      switch (radiusCompensation) {
      case RADIUS_COMPENSATION_LEFT:
        writeBlock(gMotionModal.format(0), gFormat.format(41), x, y, z);
        break;
      case RADIUS_COMPENSATION_RIGHT:
        writeBlock(gMotionModal.format(0), gFormat.format(42), x, y, z);
        break;
      default:
        writeBlock(gMotionModal.format(0), gFormat.format(40), x, y, z);
    } else {
      writeBlock(gMotionModal.format(0), x, y, z);
    forceFeed();
var resetFeed = false;
function onLinear(_x, _y, _z, feed) {
  if (isSpeedFeedSynchronizationActive()) {
    resetFeed = true;
    var threadPitch = getParameter("operation:threadPitch");
    var threadsPerInch = 1.0/threadPitch; // per mm for metric
    writeBlock(gMotionModal.format(32), xOutput.format(_x), yOutput.format(_y), zOutput.format(_z), pitchOutput.format(1/threadsPerInch));
    return;
  if (resetFeed) {
    resetFeed = false;
    forceFeed();
  var f = getFeed(feed);
  if (x || y || z) {
      writeBlock(gPlaneModal.format(18));
        writeBlock(gMotionModal.format(isSpeedFeedSynchronizationActive() ? 32 : 1), gFormat.format(41), x, y, z, f);
        break;
        writeBlock(gMotionModal.format(isSpeedFeedSynchronizationActive() ? 32 : 1), gFormat.format(42), x, y, z, f);
        break;
      default:
        writeBlock(gMotionModal.format(isSpeedFeedSynchronizationActive() ? 32 : 1), gFormat.format(40), x, y, z, f);
    } else {
      writeBlock(gMotionModal.format(isSpeedFeedSynchronizationActive() ? 32 : 1), x, y, z, f);
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      forceFeed(); // force feed on next line
    } else {
      writeBlock(gMotionModal.format(isSpeedFeedSynchronizationActive() ? 32 : 1), f);
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
    error(localize("Speed-feed synchronization is not supported for circular moves."));
    return;
    error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
    return;
  var start = getCurrentPosition();
  if (isFullCircle()) {
    if (properties.useRadius || isHelical()) { // radius mode does not support full arcs
      linearize(tolerance);
      return;
    switch (getCircularPlane()) {
    case PLANE_XY:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    default:
  } else if (!properties.useRadius) {
    case PLANE_XY:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gAbsIncModal.format(90), gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), jOutput.format(cy - start.y, 0), kOutput.format(cz - start.z, 0), getFeed(feed));
      break;
    default:
  } else { // use radius mode
    var r = getCircularRadius();
    if (toDeg(getCircularSweep()) > (180 + 1e-9)) {
      r = -r; // allow up to <360 deg arcs
    case PLANE_XY:
      writeBlock(gPlaneModal.format(17), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    case PLANE_ZX:
      writeBlock(gPlaneModal.format(18), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    case PLANE_YZ:
      writeBlock(gPlaneModal.format(19), gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), "R" + rFormat.format(r), getFeed(feed));
      break;
    default:
function onSpindleSpeed(spindleSpeed) {
  writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
function getCommonCycle(x, y, z, r) {
  forceXYZ(); // force xyz on first drill hole of any cycle
  return [xOutput.format(x), yOutput.format(y),
    zOutput.format(z),
    "R" + spatialFormat.format(r)];
function onCyclePoint(x, y, z) {
  if (isSameDirection(currentSection.workPlane.forward, new Vector(0, 0, 1)) ||
    writeBlock(gPlaneModal.format(17)); // XY plane
  } else {
    expandCyclePoint(x, y, z);
    return;
  switch (cycleType) {
  case "thread-turning":
    error(localize("Thread turning cycle is not supported. Please disable the 'use cycle' setting for the threading operation to output thread as G32."));
    return;
  if (isFirstCyclePoint()) {
    switch (gPlaneModal.getCurrent()) {
    case 17:
      writeBlock(gMotionModal.format(0), zOutput.format(cycle.clearance));
      break;
    case 18:
      writeBlock(gMotionModal.format(0), yOutput.format(cycle.clearance));
      break;
    case 19:
      writeBlock(gMotionModal.format(0), xOutput.format(cycle.clearance));
      break;
    default:
      error(localize("Unsupported drilling orientation."));
      return;
    repositionToCycleClearance(cycle, x, y, z);
    // return to initial Z which is clearance plane and set absolute mode
    var F = cycle.feedrate;
    var P = (cycle.dwell == 0) ? 0 : clamp(0, cycle.dwell, 99999999); // in seconds
    case "drilling":
      writeBlock(
        gRetractModal.format(98), gCycleModal.format(81),
        getCommonCycle(x, y, z, cycle.retract),
        feedOutput.format(F)
      break;
    case "counter-boring":
      if (P > 0) {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(82),
          "P" + secFormat.format(P),
      } else {
        writeBlock(
      break;
    case "chip-breaking":
      // cycle.accumulatedDepth is ignored
      if (P > 0) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(83),
          "Q" + spatialFormat.format(cycle.incrementalDepth),
      break;
    case "deep-drilling":
      if (P > 0) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(73),
      break;
    case "tapping":
    case "left-tapping":
    case "right-tapping":
    case "tapping-with-chip-breaking":
    case "left-tapping-with-chip-breaking":
    case "right-tapping-with-chip-breaking":
      error(localize("tapping cycles are not supported."));
      return;
    case "fine-boring":
      error(localize("fine-boring cycle is not supported."));
      break;
    case "back-boring":
      error(localize("back-boring cycle is not supported."));
      break;
    case "reaming":
      writeBlock(
        gRetractModal.format(98), gCycleModal.format(85),
      break;
    case "stop-boring":
      writeBlock(
        gRetractModal.format(98), gCycleModal.format(86),
      break;
    case "boring":
      if (P > 0) {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(89),
      } else {
        writeBlock(
      break;
    case "circular-pocket-milling":
      error(localize("circular-mill cycle is not supported."));
      break;
    case "bore-milling":
      error(localize("bore-mill cycle is not supported."));
      break;
    case "thread-milling":
      error(localize("thread-mill cycle is not supported."));
      break;
    default:
  } else {
    if (cycleExpanded) {
    } else {
      var _x = xOutput.format(x);
      var _y = yOutput.format(y);
      var _z = zOutput.format(z);
      if (!_x && !_y && !_z) {
        case 17: // XY
          xOutput.reset(); // at least one axis is required
          break;
        case 18: // ZX
          zOutput.reset(); // at least one axis is required
          break;
        case 19: // YZ
          yOutput.reset(); // at least one axis is required
          break;
      writeBlock(_x, _y, _z);
function onCycleEnd() {
  if (!cycleExpanded) {
      forceFeed();
      xOutput.reset();
      zOutput.reset();
      break;
    default:
      writeBlock(gCycleModal.format(80));
      gRetractModal.reset();
var currentCoolantMode = COOLANT_OFF;
function setCoolant(coolant) {
  if (coolant == currentCoolantMode) {
    return; // coolant is already active
  var m = undefined;
  if (coolant == COOLANT_OFF) {
    writeBlock((currentCoolantMode == COOLANT_THROUGH_TOOL) ? getCode("COOLANT_THROUGH_TOOL_OFF") : getCode("COOLANT_OFF"));
    return;
  switch (coolant) {
  case COOLANT_FLOOD:
    m = getCode("COOLANT_FLOOD_ON");
    break;
  case COOLANT_THROUGH_TOOL:
    m = getCode("COOLANT_THROUGH_TOOL_ON");
    break;
  default:
    onUnsupportedCoolant(coolant);
    m = getCode("COOLANT_OFF");
  if (m) {
    writeBlock(m);
    currentCoolantMode = coolant;
function onCommand(command) {
  switch (command) {
  case COMMAND_COOLANT_OFF:
    setCoolant(COOLANT_OFF);
    break;
  case COMMAND_COOLANT_ON:
    setCoolant(COOLANT_FLOOD);
    break;
  case COMMAND_LOCK_MULTI_AXIS:
    break;
  case COMMAND_UNLOCK_MULTI_AXIS:
    break;
  case COMMAND_START_CHIP_TRANSPORT:
    break;
  case COMMAND_STOP_CHIP_TRANSPORT:
    break;
  case COMMAND_BREAK_CONTROL:
    break;
  case COMMAND_TOOL_MEASURE:
    break;
  case COMMAND_ACTIVATE_SPEED_FEED_SYNCHRONIZATION:
    break;
  case COMMAND_DEACTIVATE_SPEED_FEED_SYNCHRONIZATION:
    break;
  case COMMAND_STOP:
    writeBlock(mFormat.format(0));
    forceSpindleSpeed = true;
    break;
  case COMMAND_OPTIONAL_STOP:
    writeBlock(mFormat.format(1));
    break;
  case COMMAND_END:
    writeBlock(mFormat.format(2));
    break;
  case COMMAND_SPINDLE_CLOCKWISE:
    switch (currentSection.spindle) {
    case SPINDLE_PRIMARY:
      writeBlock(mFormat.format(3));
      break;
    case SPINDLE_SECONDARY:
      writeBlock(mFormat.format(143));
      break;
    break;
  case COMMAND_SPINDLE_COUNTERCLOCKWISE:
      writeBlock(mFormat.format(4));
      break;
      writeBlock(mFormat.format(144));
      break;
    break;
  case COMMAND_START_SPINDLE:
    onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
  case COMMAND_STOP_SPINDLE:
      writeBlock(mFormat.format(5));
      break;
      writeBlock(mFormat.format(145));
      break;
    break;
  case COMMAND_ORIENTATE_SPINDLE:
    if (getSpindle() == 0) {
      writeBlock(mFormat.format(19)); // use P or R to set angle (optional)
    } else {
      writeBlock(mFormat.format(119));
    break;
  //case COMMAND_CLAMP: // add support for clamping
  //case COMMAND_UNCLAMP: // add support for clamping
  default:
    onUnsupportedCommand(command);
function engagePartCatcher(engage) {
  if (engage) {
    // catch part here
    writeBlock(getCode("PART_CATCHER_ON"), formatComment(localize("PART CATCHER ON")));
  } else {
    writeBlock(gFormat.format(53), gMotionModal.format(0), "X" + xFormat.format(properties.g53HomePositionX)); // retract
    writeBlock(gFormat.format(53), gMotionModal.format(0), "Z" + zFormat.format(properties.g53HomePositionZ)); // retract
    writeBlock(getCode("PART_CATCHER_OFF"), formatComment(localize("PART CATCHER OFF")));
    forceXYZ();
function onSectionEnd() {
    engagePartCatcher(false);
  forceAny();
function onClose() {
  writeln("");
  // we might want to retract in Z before X
  // writeBlock(gFormat.format(28), "U" + xFormat.format(0)); // retract
  forceXYZ();
  if (!machineConfiguration.hasHomePositionX() && !machineConfiguration.hasHomePositionY()) {
    writeBlock(gAbsIncModal.format(91), gFormat.format(28), "X" + xFormat.format(0), conditional(yOutput.isEnabled(), "Y" + yFormat.format(0)), "Z" + zFormat.format(0)); // return to home
  } else {
    var homeX;
    if (machineConfiguration.hasHomePositionX()) {
      homeX = xOutput.format(machineConfiguration.getHomePositionX());
    var homeY;
    if (yOutput.isEnabled() && machineConfiguration.hasHomePositionY()) {
      homeY = yOutput.format(machineConfiguration.getHomePositionY());
    writeBlock(gFormat.format(53), gMotionModal.format(0), homeX, homeY, zOutput.format(machineConfiguration.getRetractPlane()));
  onImpliedCommand(COMMAND_END);
  onImpliedCommand(COMMAND_STOP_SPINDLE);
  writeBlock(mFormat.format(30)); // stop program, spindle stop, coolant off
  writeln("%");
{/code]
Üstelik SVN var. SVN'nin ne kadar kullanışlı olduğunu yazılımcılar bilir.
svn'den kastım git zaten. Source Control'un adı biz dedelerde svn kaldı.
Turning uğraşmadım. Tornam yok. Ama diğer konularda sıkıntı yok zaten.
solid bırakılır mı hiç:rolleyes:
Autodesk HSMWorks varmış. Solidworks içinde çalışıyor. SolidCAM gibi. Onu bir denemek istiyorum.
camworks te var abi onada bir bak istersen solid eklentisi olarak çalışıyor
Bir kaç gündür HSM ile uğraşıyorum. Kendi Mach3 post processor'unu deniyorum. Cam'de her şey düzgün görünürken gcode'da arklar simetrik görünüyor. Yani ben saat yönünde yarım daire çizdirirken o ters tarafa tam daire çiziyor ve parçanın içine dalıyor.
TalhaSahin
