DC motor pwm hız kontrolü
23 May 2014
merhaba sıcaklık sensörü kullanarak dc motor hız kontrolü yapan devre şeması lazım ancak kullanılacak malzemeler önemli .
During the project implementation, you will use a power supply as the only input. In your circuit
design, in addition to op-amps, you may use any types of resistors, capacitors, inductors and
diodes. Moreover, since output current of op-amps may be limited to drive a DC motor, you may
need additional motor driving ICs such as L293D. As a temperature sensor you may use LM 35
chip.
vermı yardım edebilecek olan acaba.
tırcı7106
