Böyle yapabilirsin...
Düzeltme;Yukarıdaki devre C koduymuş.Basicte şöyle olacak.
' LCD clock program using Dallas1202/1302 RTC
Include "MODEDEFS.BAS" ' Include Shiftin/out modes
Define LCD_DREG PORTD ' Define LCD connections
Define LCD_DBIT 4
Define LCD_RSREG PORTE
Define LCD_RSBIT 0
Define LCD_EREG PORTE
Define LCD_EBIT 1
' Alias pins
RST var PORTA.2
IO var PORTC.1
SCLK var PORTC.3
' Allocate variables
rtcyear var byte
rtcday var byte
rtcmonth var byte
rtcdate var byte
rtchr var byte
rtcmin var byte
rtcsec var byte
rtccontrol var byte
Low RST ' Reset RTC
Low SCLK
ADCON1 = 7 ' PORTA and E digital
Low PORTE.2 ' LCD R/W low = write
Pause 100 ' Wait for LCD to startup
' Set initial time to 8:00:00AM 07/16/99
rtcyear = $99
rtcday = $06
rtcmonth = $07
rtcdate = $16
rtchr = $08
rtcmin = 0
rtcsec = 0
Gosub settime ' Set the time
Goto mainloop ' Skip subroutines
' Subroutine to write time to RTC
settime:
RST = 1 ' Ready for transfer
' Enable write
Shiftout IO, SCLK, LSBFIRST, [$8e, 0]
RST = 0 ' Reset RTC
' Write all 8 RTC registers in burst mode
Shiftout IO, SCLK, LSBFIRST, [$be, rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, 0]
RST = 0 ' Reset RTC
Return
' Subroutine to read time from RTC
gettime:
Shiftout IO, SCLK, LSBFIRST, [$bf] ' Read all 8 RTC registers in burst mode
Shiftin IO, SCLK, LSBPRE, [rtcsec, rtcmin, rtchr, rtcdate, rtcmonth, rtcday, rtcyear, rtccontrol]
RST = 0 ' Reset RTC
Return
' Main program loop - in this case, it only updates the LCD with the time
mainloop:
Gosub gettime ' Read the time from the RTC
' Display time on LCD
Lcdout $fe, 1, hex2 rtcmonth, "/", hex2 rtcdate, "/" , hex2 rtcyear,_
" ", hex2 rtchr, ":", hex2 rtcmin, ":", hex2 rtcsec
Pause 300 ' Do it about 3 times a second
Goto mainloop ' Do it forever
End
