occuplus
- Katılım
- 31 Mar 2021
- Mesajlar
- 76
- Puanları
- 1
- Yaş
- 44
Elimde 40A lik şarj kontrol cihazı var. Sabah ve akşam verimi arttırmak istiyorum.
Ekteki bilgilere göre 12v luk sistem için 780W'a kadar arttırabilir miyim?
"if the power of PV array exceeds the rated
charging power of controller, then the charging time as per the rated power will be
prolonged, so that more energy can be obtained for charging the battery. However, in
the practical application, the maximum power of PV array shall be not greater than 1.5
x the rated charging power of controller. If the maximum power of PV array exceeds
the rated charging power of controller too much, it will not only cause the waste of PV
modules, but also increase the open-circuit voltage of PV array due to the influence of
environmental temperature, which may make the probability of damage to the
controller rise. Therefore, it is very important to configure the system reasonably. For
the recommended maximum power of PV array for this controller, please refer to the
table below:"
table below:"
