Temperature Sensor Resistance Readings
Temperature = 0C
K Ohms = 35K
Temperature = 10C
K Ohms = 20K
Temperature = 20C
K Ohms = 13K
Temperature = 30C
K Ohms = 8K
Fault Codes for RAHC, YKHC & YUHC Models
Indoor lights
Operation = Flash
Timer = Flash
Defrost = Flash
Faults = Outdoor Problem
Operation =
Timer =
Defrost = Flash
Faults = ID Air Sensor Fail
Operation = Flash
Timer =
Defrost =
Faults = ID Pipe Sensor Fail
Operation =
Timer =
Defrost = Flash
Faults = OD Pipe Sensor Fail
Operation = Flash
Timer = Flash
Defrost =
Faults = PCB Fail
Outdoor LEDS 3ph models only
LED 1 = Flash
LED 2 = Off
LED 3 = Off
Faults = Phase Error
LED 1 = Flash
LED 2 = Flash
LED 3 = Off
Faults = Pressure Switch
LED 1 = Off
LED 2 = Off
LED 3 = Flash
Faults = Overcurrent
LED 1 = Off
LED 2 = Flash
LED 3 = Flash
LED 1 = Off
LED 2 = Flash
LED 3 = Off
Faults = OD Air Sensor
LED 1 = Flash
LED 2 = Flash
LED 3 = Flash
Faults = Hi Temp Protection
HVHC Inverter Fault Codes
Indoor Display = E0
ID PCB Fail
Outdoor LCDs
1 = On
2 Red = Off
3 Green = Off
4 Yellow = Off
Connected to Power
Indoor Display = E1
Comms Fail
Outdoor LCDs
1 = Off
2 Red = Off
3 Green = Off
4 Yellow = Off
Power or OD PCB Fail
Indoor Display = E3
Power Abnormal
Outdoor LCDs
1 = On
2 Red = On
3 Green = Off
4 Yellow = Off
Comms Fail
Indoor Display = E4
OD Sensor Fail
Outdoor LCDs
1 = On
2 Red = Off
3 Green = Off
4 Yellow = On
Compressor Overcurrent
Indoor Display = E5
ID Sensor Fail
Outdoor LCDs
1 = On
2 Red = Off
3 Green = Flash
4 Yellow = Flash
OD Air Sensor Fail E5
Indoor Display = E6
Inverter Module
Outdoor LCDs
1 = On
2 Red = Flash
3 Green = Off
4 Yellow = Flash
OD Pipe Sensor Fail E5
Indoor Display = PO
IPM Protection
Outdoor LCDs
1 = On
2 Red = On
3 Green = Flash
4 Yellow = On
OD Power Supply P1
Indoor Display = P1
OD Power Supply
Outdoor LCDs
1 = On
2 Red = Off
3 Green = On
4 Yellow = Off
IPM Protection P0
Indoor Display = P2
Compressor Hi Temp
Outdoor LCDs
1 = On
2 Red = Off
3 Green = On
4 Yellow = On
Compressor Temp P2
Indoor Display = P3
Outdoor Low Temp
Outdoor LCDs
1 = On
2 Red = On
3 Green = Off
4 Yellow = Off
Comms E1
Indoor Display = P4
Inverter/Compressor Fail
Outdoor LCDs
1 = On
2 Red = On
3 Green = Flash
4 Yellow = Flash
Inv / Comp Fail P4
Model HDU-24CA03/M(R1) HDU-28CA03/M(R1) HDU-36CA03/M(R1) HDU-42CA03/M(R1)
Model HSU-09/12HVA103/R2(DB)FOR Eorope
Code = E0
Flash time of
compressor
running
indicate lamp = 10
Trouble contents (old) = drainage system trouble
Trouble contents (new) = drainage system trouble
Code = E1
Flash time of
compressor
running
indicate lamp = 1
Trouble contents (old) = indoor temperature sensor broken
Trouble contents (new) = indoor temperature sensor broken
Code = E2
Flash time of
compressor
running
indicate lamp = 2
Trouble contents (old) = indoor coil temperature sensor broken
Trouble contents (new) = indoor coil temperature sensor broken
Code = E3
Flash time of
compressor
running
indicate lamp = 3
Trouble contents (old) = outdoor temperature sensor broken
Trouble contents (new) = outdoor temperature sensor broken
Code = E4
Flash time of
compressor
running
indicate lamp = 4
Trouble contents (old) = outdoor coil temperature sensor broken
Trouble contents (new) = outdoor coil temperature sensor broken
Code = E5
Flash time of
compressor
running
indicate lamp = 5
Trouble contents (old) = over current protect limit
Trouble contents (new) = over current protect limit
Code = E6
Flash time of
compressor
running
indicate lamp = 6
Trouble contents (old) = pressure protect
Trouble contents (new) = pressure protect
Code = E7
Flash time of
compressor
running
indicate lamp = 7
Trouble contents (old) = communication trouble between wired remote controller and indoor unit.
Trouble contents (new) = three phase protect
Code = E8
Flash time of
compressor
running
indicate lamp = 8
Trouble contents (old) = communication trouble between indoor and outdoor unit.
Trouble contents (new) = Communication trouble between wired remote controller and indoor unit
Code = E9
Flash time of
compressor
running
indicate lamp = 9
Trouble contents (old) = three phase protect
Trouble contents (new) = communication trouble between indoor and outdoor unit
Error Codes and Description indoor and outdoor display(1)
Indoor and Outdoor = E7
Indoor Malfunction =
Code indication
Indoor =
Outdoor (LED1 flash times) = 15
Description = Communication fault between indoor and outdoor units
Indoor Malfunction = E1
Code indication
Indoor =
Description = Room temperature sensor failure
Indoor Malfunction = E2
Code indication
Indoor =
Description = Heat-exchange sensor failure
Indoor Malfunction = E4
Code indication
Indoor =
Description = Indoor EEPROM error
Indoor Malfunction = E14
Code indication
Indoor =
Description = Indoor fan motor malfunction
Indoor Malfunction = E9
Code indication
Indoor =
Description = High work-E9 intense protection
Error Codes and Description indoor and outdoor display(2)
Outdoor Malfunction
Code Indication
Indoor = F12
Description = Outdoor EEPROM error
Outdoor Malfunction
Code Indication
Indoor = F11
Outdoor (LED1 flash times) = 2
Description = The protection of IPM
Outdoor Malfunction
Code Indication
Indoor = F22
Outdoor (LED1 flash times) = 3
Description = Over current protection of AC electricity for the outdoor model
Outdoor Malfunction
Code Indication
Indoor = F11
Outdoor (LED1 flash times) = 4
Description = Communication fault between the IPM and outdoor PCB
Outdoor Malfunction
Code Indication
Indoor =
Outdoor (LED1 flash times) = 5
Description = Over pressure or Overheat protection for the compressor
Outdoor Malfunction
Code Indication
Indoor = F11
Outdoor (LED1 flash times) = 6
Description = Power voltage is too high or low
Outdoor Malfunction
Code Indication
Indoor = F4
Outdoor (LED1 flash times) = 8
Description = Overheat protection for exhaust temperature
Outdoor Malfunction
Code Indication
Indoor =
Outdoor (LED1 flash times) = 9
Description = outdoor fan motor malfunction
Outdoor Malfunction
Code Indication
Indoor = F21
Outdoor (LED1 flash times) = 10
Description = Frost-removing temperature sensor failure
Outdoor Malfunction
Code Indication
Indoor = F6
Outdoor (LED1 flash times) = 12
Description = Ambient temperature sensor failure
Outdoor Malfunction
Code Indication
Indoor = F25
Outdoor (LED1 flash times) = 13
Description = Exhaust temperature sensor failure
Outdoor Malfunction
Code Indication
Indoor =
Outdoor (LED1 flash times) = 18
Description = deviate from the normal for the compressor
Outdoor Malfunction
Code Indication
Indoor = F11
Outdoor (LED1 flash times) = 19
Description = Loop of the station detect error
Outdoor Malfunction
Code Indication
Indoor = - - -
Outdoor (LED1 flash times) = 24
Description = Over current of the compressor
Outdoor Malfunction
Code Indication
Indoor = - - -
Outdoor (LED1 flash times) = 25
Description = Over current protection for single-past of the compressor
Mr.Slim A-control error code list
Display of remote controller
Code EA
Error detail Mis-wiring of indoor/outdoor unit. exceed the number of indoor unit connection.
Inspected unit Outdoor.
Code Eb
Error detail Mis-wiring of indoor/outdoor unit. (mis-wiring disconnection)
Code EC
Error detail Start-up time over
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Code E7
Error detail Indoor/outdoor unit transmission error (transmitting error).
Code E8
Code E9
Code E0 Error detail Remote control transmission error (signal receiving error)
Inspected unit Remote control
Code E3
Error detail Remote control transmission error (transmitting error)
Inspected unit Remote control.
Code E4
Code E5
Code EF
Error detail M-NET transmission error
Inspected unit Indoor and outdoor.
Code Ed
Error detail Serial transmission error
Code P1
Error detail Abnolmality of room temperature thermistor (TH1).
Code P2
Error detail Abnormality of pipe temperature themistor/liquid (TH2).
Code P4
Error detail Abnomarlity of drain sensor (DS)
Code P5
Error detail Malfunction of drain-up machine.
Code P6
Error detail Freezing/overheating protection detect.
Code P8
Error detail Abnormality of pipe temperature.
Code P9
Error detail Anormality of pipe temperature thermistor/condenser/evaporator (TH5)
Code F1
Error detail Reverse phase detection.
Code F2
Error detail L3 open phase detection.
Code F3
Error detail 63L connector open.
Code F4
Error detail 49C connector open.
Code F9
Error detail Connector 2 or more open.
Code FA
Error detail L2-phased open phase or 51CM connector open.
Code F7
Error detail Reverse phase detection circuit (p.c.board) fault.
Code F8
Error detail Input circuit fault.
Code U2
Error detail Abnormal high discharging temperature.
Code U2
Error detail Inner thermostat (49C) operation.
Code U1
Error detail Abnormal high pressure (high pressure swicth 63H worked)
Code U1
Error detail Direct cut operation.
Code UE
Error detail High pressure error (ball valve closed)
Code UL
Error detail Abnormal low pressure.
Code Ud
Error detail Over heat protection
Code U6
Error detail Compressor over current (overload) cut off.
Code UA
Error detail Compressor over current (terminal relay operation).
Code UF
Error detail Compressor over current (start-up locked) cut off.
Code UF
Error detail Compressor over current (operating locked) cut off.
Code UH
Error detail Current sensor error.
Code U3
Error detail Discharge thermistor short/open.
Code U4
Error detail Outdoor thermistor short/open.
Mr.Slim K-control
LED E0
Diagnosis of malfunction Transmitting/receiving signal error.
LED P1
Diagnosis of malfunction Intake air sensor abnormal.
LED P2
Diagnosis of malfunction Pipe sensor abnormal.
LED P4
Diagnosis of malfunction Drain sensor abnormal.
LED P5
Diagnosis of malfunction Malfunctioning of the drain overflow protecting mechanism.
LED P6
Diagnosis of malfunction Abnomality of the coil frost/overheating protection mode.
LED P3
Diagnosis of malfunction System error (transmitting/receiving signal).
LED P7
Diagnosis of malfunction System error (address)
LED P8
Diagnosis of malfunction Outdoor unit malfunction
Mr.Slim K-control PUH-EK
Outdoor unit
LED ON = Operation status
LED Flash = Check code diplay
LED LD1
LED ON Compressor directive
LED Flash Reverse phase detect
LED LD2
LED ON Heating directive
LED Flash Open phase detect
LED LD3
LED ON During 63H1 operation
LED Flash Pipe sensor short/open
LED LD4
LED ON Compressor ON
LED Flash High pressure swicth (63H2) operation.
LED LD5
LED ON Outdoor fan ON
LED Flash Over current relay (51CM) operation.
LED LD6
LED ON 4-way valve ON
LED Flash Thermal swicth (26C) operation.
LED LD7
LED ON Bypass valve ON
LED Flash Thermistor (TH3) overheat protection.
LED LD8
LED ON Crankcase heater ON
LED Flash Devective input.
Fujitsu Inverter Error Codes
To Interrogate
When E:EE is displayed switch unit off and press the temp up and temp down buttons simultaneously for 3 seconds.
To Return to Normal Operation
Press Temp Up and Temp Down Buttons together for 3 seconds.
To Initiate Test Operation
Switch Unit Off & Press Master & Fan Buttons together for 3 seconds.
Press Start/Stop to Initiate.
Changing the Sensor Position
The unit can sense the air temperature at the unit or controller Turn Unit Off To change press THERMOSENSOR button for 5 seconds to unlock
Toggle the THERMOSENSOR button & controller is displayed Set to desired setting (unit or controller)
Press THERMOSENSOR button for 5 seconds to lock
Two Handsets/1 Unit - set on RC DIP SWs
Single handset DIP SW1 is On & 2 is Off
Dual Handset Master Both On & Slave both Off
Group Control up to 16 Unit from 1 RC Handset
Set DIP SW3 on RC to ON
Set Each ID Unit Rotary SW to Unit Address (0-15) in series
Auto Restart on Power Failure
DIP SW2-3 on ID Unit. Off is autorestart (std)/On is manual Restart
Auto Changeover
DIP SW5 on RC. On is autochangeover (std)/Off is Manual
Memory Retention on Power Failure
Dip SW6 on RC. On is Memory/Off is no memory
Wired Remote Control Models
Code Consists of Indoor Unit Address Followed by the Fault Code Below.
No E denotes no fault.
OO ID to RC Comms Fail
O1 ID to OD Comms Fail
O2 ID Air Sensor Open
O3 ID Air Sensor Close
O4 ID Pipe Sensor Open
O5 ID Pipe Sensor Close
O6 OD Pipe Sensor Fail
O8 Power Source Connection Failure
O9 Drain Problem
OA OD Air Sensor Fail
OC Discharge sensor Fail
OE Outdoor High Pressure
11 OD PCB Fail
12 ID Fan Fail
13 OD Signal Abnormal
14 OD EEPROM Fail
15 Compressor Temp Failure
16 Pressure Switch Error
17 IPM Error
18 CT Error
19 Active Filter Module Error
1A Compressor Failure
1B OD Fan Failure
1C Inverter to PCB Comms Fail
1D 2 Way Valve sensor Fail
1E Expansion Valve Error
1F Connection ID Unit Error
Outdoor PCB Fault Codes
Inverter OD Unit PCBs (1 red LED)
OD PCB LED Pulses = 1
Models 9-30 = Comms Failure
Models 36-54 = Comms Failure
OD PCB LED Pulses = 2
Models 9-30 = Disch Sensor Fail
Models 36-54 = Disch Sensor Fail
OD PCB LED Pulses = 3
Models 9-30 = Pipe Sensor Fail
Models 36-54 = Pipe Sensor Fail
OD PCB LED Pulses = 4
Models 9-30 = Air Sensor Fail
Models 36-54 = Air Sensor Fail
OD PCB LED Pulses = 5
Models 9-30 = 2 Way Valve Sensor
Models 36-54 =
OD PCB LED Pulses = 6
Models 9-30 = 3 Way Valve Sensor
Models 36-54 =
OD PCB LED Pulses = 7
Models 9-30 = Compressor Thermistor
Models 36-54 = Compressor Thermistor
OD PCB LED Pulses = 8
Models 9-30 = Pressure Switch
Models 36-54 = Heat Sink Sensor Fail
OD PCB LED Pulses = 9
Models 9-30 = Indoor Comms Error
Models 36-54 = Pressure Switch
OD PCB LED Pulses = 10
Models 9-30 = Current Trip
Models 36-54 =
OD PCB LED Pulses = 11
Models 9-30 = CT Fail
Models 36-54 =
OD PCB LED Pulses = 12
Models 9-30 = Compressor Position Fail
Models 36-54 = IPM Error
OD PCB LED Pulses = 13
Models 9-30 = Compressor Start Fail
Models 36-54 = Compressor Position Fail
OD PCB LED Pulses = 14
Models 9-30 = Timer Failure
Models 36-54 = Compressor Start Fail
OD PCB LED Pulses = 15
Models 9-30 =
Models 36-54 = OD Upper Fan Fail
OD PCB LED Pulses = 16
Models 9-30 =
Models 36-54 = OD Lower Fan Fail
OD PCB LED Pulses = Slow Blink
Models 9-30 =
Models 36-54 = Protect Operation
Non Inverter OD PCBs (2 red LEDs)
LED1 = Blinks
LED2 = Blinks
OD PCB Fail
LED1 = 1 Pulse
LED2 = Lit
Power Source Failure
LED1 = 2 Pulse
LED2 = Lit
OD Disch Temp Sensor
LED1 = 3 Pulse
LED2 = Lit
OD Pipe Sensor
LED1 = 4 Pulse
LED2 = Lit
OD Air Sensor
LED1 = 5 Pulse
LED2 = Lit
Comms Failure
LED1 = 6 Pulse
LED2 = Lit
Indoor Unit Error
LED1 = 7 Pulse
LED2 = Lit
High Discharge Temp
LED1 = 8 Pulse
LED2 = Lit
High Pressure
LED1 = 9 Pulse
LED2 = Lit
Compressor Temp Abnormal
LED1 = 10 Pulse
LED2 = Lit
Compressor Temp Sensor Fail
Inverter Multi AOY30
This has 4 LEDs A,B, C & D to denote which circuit has the fault
Up to 8 flashes - faults are identical to above 9-30 Single System
9 Pressure Switch A
10 Pressure Switch B
11 Indoor Unit Indexing Problem
12 IPM Fail
13 Compressor Position Fail
14 Compressor Fail
15 OD Fan Upper Fail
16 OD Fan Lower Fail
17 PCB Fail
Interconnecting Wiring
CO Multis 2 (Live) 1 (Neutral) 3 (Comms)
HP Multis 1 (Live) 2 (Neutral) 3 (Comms)
AOY90T 3 (Live) 2 (Neutral) 1 (Comms)
ALL OTHERS 1 or L 2 or N 3
We recommend external pumps have their own power supply.
Taking Power for a pump from the unit is a major source of Errors (CLIMATE CENTRE)
Pipework
• Pipe sizes and lengths should be as the relevant Technical Guide
• Both lines should be insulated
• No line accessories or oil traps should be fitted
• In cooling mode both pipes should be between 0 and 10C - the suction line should sweat, but not freeze
• In heating moded both pipes should be between 30 an 60C
• Pipework should be refrigeration quality
• Refrigerant should be R22, unless stated on the outdoor unit
• Look for restrictions. They could cause compressor failures.
Outdoor Unit
• Discharge temperature should be between 50 & 70C
• Suction temperature should be between -3 & 4C
• If fan switches off check for high discharge temperature
• Check Suction Line is sweating – problem if not!
• Hot Recip. Compressor = PROBLEM!
• Sweating/Frost on expansion line – undercharged
Indoor Unit
• Is it level? Have we adequate drainage?
• Smells are always due to site conditions or drains
• Flashing lights? = Fault Diagnostics - see over
• When were the filters last cleaned?
• Is the unit too large/small (between 5/20 air circs / hr)
• Is it on Timer/Test Mode
Controller
• EE:EE on LCD handset - fault diagnostics - see over
• Is the handset too far away?
• When were the batteries changed last?
• Heat Pump models 7-14 – NOT auto changeover
• Timer is one shot, unless it has ‘repeat’ mode
• With wired handset, check for interference. Cable should be screened
Wiring
• In general interconnecting wiring is 240 Volt, but see chart for details
• With LCD wired handset models, Terminal 3 is the Live Not Terminal 1
NEVER apply mains voltage to Terminal 1 on these models
• With LCD wired handset models wiring should be screened
• Check Voltage drops! Check it isn’t down to Earth!
• Has it got a timeclock/BMS interface?
• Interconnecting cables MUST be circular crimped
What the separate Wires do in the interconnecting Cables
Note – Wires are 240V Live except where marked neutral or Earth or signal
Cables marked Signal are digital pulses and you should not attempt to measure these with a meter.
Wired Controllers - Fault diagnostics
A Fault Condition is signalled by EE:EE appearing on the LCD panel.
The unit should be interrogated by switching it off on the handset then
pressing either the down arrows on the SET TIME and TEMP/DAY buttons
together for 3 seconds for 7 day models or the ENERGY SAVE & ZONE
CONTROL buttons for other models.
The Failure code is in 2 parts - Fault and Address.
The Fault Code is an E code. The second is the unit address for multi
linked systems - with single units this is always 00. 7 day models have the
fault code as shown in the table below above the address.
Other models have the codes below, minus the 0, followed by the address
- e.g. E9:00 denoting Float Switch on Unit 0.
Code = E:0
Fault = I/U - R/C Comms
Diagnosis = Check R/C wiring. Interference?
Code = E:01
Fault = I/U - O/U Comms
Diagnosis = Check intercon. wiring. Interference
Code = E:02
Fault = Room Sensor Open
Diagnosis = Sensor Missing
Code = E:03
Fault = Room Sensor Short
Diagnosis = Sensor Faulty
Code = E:04
Fault = I/U Pipe Sensor Open
Code = E:05
Fault = I/U Pipe Sensor Short
Code = E:06
Fault = O/U Pipe Sensor Open
Code = E:07
Fault = O/U Pipe Sensor Short
Code = E:08
Fault = Power Source Error
Diagnosis = Incorrect Power Supply
Code = E:09
Fault = Float Switch
Diagnosis = Check Drains - High Water Level
Code = E:0A
Fault = O/U Air Sensor Open
Code = E:0C
Fault = Disch Sensor Open
Code = E:0D
Fault = Disch Sensor Short
Code = E:0F
Fault = High Disch Temp
Diagnosis = Contamination In Pipework/Gas Shortage
Code = E:11
Fault = Model Abnormal
Diagnosis = Check PCB compatability
Code = E:12
Fault = Indoor Fan Failure
Diagnosis = Check Fan and Motor
Code = E:13
Fault = O/D Signal Abnormal
Diagnosis = Communications?
Code = E:14
Fault = Outdoor PCB Fail
Diagnosis = PCB Failure
Outdoor Unit with
A fault condition is signified by flashing red LED’s on the the outdoor PCB
if it is equipped with one. Except for multisplits and 2 LED models, the
diagnostics are shown in the table on the right.
For 2 LED models flashing signifies sensor failure and constantly lit
indicates high discharge temperature.
Fault = Signal Failure
LED1 =
LED2 =
LED3 =
LED4 = Flash
LED5 =
LED6 =
Fault = Indoor Unit Failure
LED1 =
LED2 =
LED3 =
LED4 = Flash
LED5 =
LED6 =
Fault = Discharge Sensor Fail
LED1 =
LED2 =
LED3 =
LED4 =
LED5 =
LED6 = Flash
Fault = O/D Pipe Sensor Fail
LED1 =
LED2 =
LED3 =
LED4 =
LED5 = Flash
LED6 = Flash
Fault = O/D Air Sensor Fail
LED1 =
LED2 =
LED3 = Flash
LED4 =
LED5 = Flash
LED6 =
LED1 =
LED2 = Flash
LED3 =
LED4 =
LED5 =
LED6 =
Fault = PCB
LED1 = Flash
LED2 = Flash
LED3 = Flash
LED4 = Flash
LED5 = Flash
LED6 = Flash
Fault = PCB Failure
LED1 = *
LED2 = *
LED3 = *
LED4 = *
LED5 = *
LED6 = * All Flashing Very Rapidly
Fault = High Pressure Trip
LED1 = Flash
LED2 =
LED3 =
LED4 =
LED5 =
LED6 =
Fault = Discharge Temp Trip
LED1 =
LED2 = Flash
LED3 =
LED4 =
LED5 =
LED6 =
Unit = All
Code Means:- = Power On
Red = On
Green = Off
Yellow = Off
Unit = All
Code Means:- = Timer Mode
Red = On
Green = On
Yellow = Off
Unit = All
Code Means:- = Louvre On
Red = On
Green = On or Off
Yellow = On
Unit = All
Code Means:- = HP Defrost Cont.
Red = Long pulses
Green = Off
Yellow = Off
Unit = All
Code Means:- = Test
Red = Cont. Pulse
Green = Cont. Pulse
Yellow = Off
Unit = D,E,F
Code Means:- = Power Fail
Red = On
Green = Cont Long
Yellow = Pulses Off
Unit = All
Code Means:- = PCB Failure
Red = Cont. Short Pulse
Green = Cont. Short Pulse
Yellow = Off
Unit = G
Code Means:- = Room Sensor Fault
Red = 1 Short Pulse
Green = Rapid Pulse
Yellow = Off
Unit = A,B,G
Code Means:- = Sensor Fault
Red = 2 Short Pulses
Green = Rapid Pulse
Yellow = Off
Unit = D,E,F
Code Means:- = Room Sensor Open/Fail
Green = Rapid Pulse
Yellow = Off
Unit = E,F
Code Means:- = Room Sensor Short
Green = Rapid Pulse
Yellow = Rapid Pulse
Unit = C
Red = 3 Short Pulses
Green = Long Pulse
Yellow = Off
Unit = D,E,F
Code Means:- = Pipe Sensor Open
Green = Rapid Pulse
Yellow = Off
Unit = E,F
Code Means:- = Pipe Sensor Short
Green = Rapid Pulse
Unit = D,E,F
Code Means:- = High Water
Red = 4 Short Pulse
Green = Rapid Pulse
Yellow = Off
Unit = F
Code Means:- = Comms Failure
Red = 5 Short Pulses
Green = Rapid Pulse
Yellow = Off
Unit = G
Red = 6 Short Pulses
Green = Rapid Pulse
Yellow = Off
Unit = B,E,F
Code Means:- = Fan Failure
Green = Rapid Pulse
Yellow = Off
Unit = F
Code Means:- = 3ph Reversal
Red = Rapid Pulse
Green = 2 Short Pulses
Yellow = Off
Unit = C
Code Means:- = Pipe Sensor Fault
Red = Long Pulse
Green = 3 Short Pulses
Yellow = Off
Unit = F OD
Red = Rapid Pulse
Yellow = Off
Unit = F OD
Red = Rapid Pulse
Unit = F OD
Code Means:- = Temp Sensor Open
Red = Rapid Pulse
Green = 4 Short
Yellow = Pulses Off
Unit = F OD
Code Means:- = Temp Sensor Short
Red = Rapid Pulse
Green = 4 Short Pulses
Unit = F
Code Means:- = Discharge Sensor Open
Red = Rapid Pulse
Green = 5 Short Pulses
Yellow = Off
Unit = F
Code Means:- = Discharge Sensor Short
Red = Rapid Pulse
Unit = F
Code Means:- = High/Low Pressure
Red = Rapid Pulse
Green = 6 Short Pulses
Yellow = Off
Unit = F
Code Means:- = High Discharge Temp
Red = Rapid Pulse 7
Green = Short Pulses
Yellow = Off
SENSOR RESISTANCES - Use to Check Thermistors across the range
Sensor At 10C At 20C At 30C
Air Temperature Sensors 20K Ohms 13K Ohms 8K Ohms
Indoor Pipe Sensor 103K Ohms 63K Ohms 40K Ohms
Outdoor Pipe Sensor 10K Ohms 6K Ohms 4K Ohms
Discharge Sensor 646K Ohms 395K Ohms 250K Ohms
Fujitsu Air Conditioner Error Codes
Fujitsu Air Conditioner Hardwired Remote Controller System Error Codes.
When EE:EE is displayed on remote control , press “Energy Save” &
“Zone Control” buttons simultaneously for longer than 3 secs.
The error code will then be displayed on the LCD.
Code Fault
E0:00 Coms error - indoor to remote
E1:00 Coms error - indoor to outdoor
E2:00 Return air thermistor open circuit
E3:00 Return air thermistor short circuit
E4:00 Indoor coil thermistor open
E5:00 Indoor coil thermistor shorted
E6:00 Outdoor coil thermistor open
E7:00 Outdoor coil thermistor shorted
EA:00 Outdoor ambient thermistor open
Eb:00 Outdoor ambient thermistor shorted
Ec:00 Discharge pipe themistor open
Ed:00 Discharge pipe thermistor shorted
EE:00 High Pressure problem
EF:00 Discharge pipe temp. Problem - too high = short of gas
Press “Energy Save” & “Zone Control” buttons simultaneously for longer
than 3 secs to return to normal operating mode
(1) Stop the air conditioner operation.
(2) Press the master control button and the fan control button simultaneously for 2 seconds or more to start the test run
(3) Press the start/stop button to stop the test run
[SELF-DIAGNOSIS]
When the error indication E:EE is displayed, follow the following items
to perform the self-diagnosis. E:EE indicates an error has occurred.
1. REMOTE CONTROLLER DISPLAY
2) Press the set temperature buttons simultaneously for 5 seconds or more to start the self-diagnosis.
Refer to the following tables for the description of each error code
(3) Press the set temperature buttons simultaneously for 5 seconds or more to stop the self-diagnosis.
Error code = 00
Error contents = Communication error (indoor unit to remote controller)
Error code = 01
Error contents = Communication error (indoor unit to outdoor unit)
Error code = 02
Error contents = Room temperature sensor open
Error code = 03
Error contents = Room temperature sensor short-circuited
Error code = 04
Error contents = Indoor heat exchanger temperature sensor open
Error code = 05
Error contents = Indoor heat exchanger temperature sensor shortcircuited
Error code = 06
Error contents = Outdoor heat exchanger temperature sensor open
Error code = 07
Error contents = Outdoor heat exchanger temperature sensor shortcircuit
Error code = 08
Error contents = Power source connection error
Error code = 09
Error contents = Float switch operated
Error code = 0A
Error contents = Outdoor temperature sensor open
Error code = 0b
Error contents = Outdoor temperature sensor short-circuited
Error code = 0c
Error contents = Discharge pipe temperature sensor open
Error code = 0d
Error contents = Discharge pipe temperature sensor short-circuited
Error code = 0E
Error contents = Outdoor high pressure abnormal
Error code = 0F
Error contents = Discharge pipe temperature abnormal
Error code = 11
Error contents = Model abnormal
Error code = 12
Error contents = Indoor fan abnormal
Error code = 13
Error contents = Outdoor signal abnormal
Error code = 14
Error contents = Outdoor EEPROM abnormal
2. OUTDOOR UNIT LEDS
When the outdoor temperature drops, the outdoor units fans may switch
to low speed.
ERROR : HEAT & COOL MODEL (REVERSE CYCLE) ONLY
The LED lamps operate as follows according to the error contents.
These pages cover the current Inverter product range.
They also cover the ARY60U, ARY54U Single and AOY19/24F/U Multi Systems.
Models with Wireless Controllers
Trouble Shooting from the Indoor Unit
Wall Mounted Single Systems ASY, ASYA & ASYB
Includes AWYZ Nokria Models
Red Light Operation = Off
Green Light Timer = 2 Flashes
Reverse Comms Fail at Startup
Green Light Timer = 3 Flashes
Reverse Comms Fail In Use
Green Light Timer = 4 Flashes
Forward Comms Fail at Startup
Green Light Timer = 5 Flashes
Forward Comms Fail In Use
Green Light Timer = 8 Flashes
Wired Remote Control Failure
Red Light Operation = 2 Flashes
Indoor Air Sensor Fail
Indoor Pipe Sensor Fail
Red Light Operation = 3 Flashes
Green Light Timer = 2 Flashes OD
Disch Sensor Fail
Green Light Timer = 3 Flashes OD
Pipe Sensor Fail
Green Light Timer = 4 Flashes OD
Air Sensor Fail
Red Light Operation = 4 Flashes
Forced Auto Switch Welded
Main Relay Welded
Power Failure
Green Light Timer = 7 Flashes
VDD Permament Stop Protection
Reverse VDD Permament Stop
Red Light Operation = 5 Flashes
Current Trip
CT Abnormal
Compressor Failure
Green Light Timer = 6 Flashes
Outdoor Fan Failure
Red Light Operation = 6 Flashes
ID Fan Motor Locked
ID Fan Motor Rotation Error
Red Light Operation = 7 Flashes
High Discharge Temperature
High Pressure
Pressure Switch Fail
Red Light Operation = 8 Flashes
Active Filter AFM Fail 1st Time
Active Filter AFM Fail 2nd Time
PFC Circuit Error
Red Light Operation = Blinking
Green Light Timer = Blinking
PCB Failure
All Other Wireless Indoor Units AUY, ABY & AWY Models
Including Multi Systems (Not J Series or VRF)
Red Light operation = On
Green Light Timer =
Yellow Light Swing =
Normal
Green Light Timer = Slow Blink
Yellow Light Swing = Slow Blink
Test
Red Light operation = Blinks
Green Light Timer = Blinks
Yellow Light Swing = Off
ID PCB Fail
Yellow Light Swing = Blinks
OD PCB Fail
Green Light Timer = 2 Pulses
OD Power Connection Failure
Green Light Timer =3 Pulses
OD Unit Pipe Sensor Fail
Green Light Timer =4 Pulses
Yellow Light Swing = Off OD
Unit Air sensor Fail
OD Unit Air sensor Short
Green Light Timer = 5 Pulses
OD Unit Disch Sensor Fail
OD Unit Disch Sensor Short
Green Light Timer = 6 Pulses
High Pressure
Green Light Timer = 7 Pulses
High Discharge or Compressor Temp
Green Light Timer = 9 Pulses
OD Unit Compressor Temp Sensor
Green Light Timer = 10 Pulses
IPM Error
Green Light Timer = 11 Pulses
CT Error
Green Light Timer = 12 Pulses
AFM Filter Error
Green Light Timer = 13 Pulses
Compressor Error
Green Light Timer = 14 Pulses
OD Fan Motor Fail
Red Light operation = 2 Pulses
Air Sensor Open
Air Sensor Closed
Red Light operation = 3 Pulses
Pipe Sensor Open
Pipe Sensor Closed
Red Light operation = 4 Pulses
Drain Problem
Red Light operation = 5 Pulses
Communication Error
OD PCB or Wiring Error
Red Light operation = 6 Pulses
Indoor Fan Failure
Wall Mounted Multi Models
Initial Display
Red = 2 Flashes
Green = Blinks
Meaning = ID Sensor Failure
Further Interrogation by Pressing Test Button on Infra Red RC
Red = Blinks
Green = 2 Flashes
ID Air Sensor
Initial Display
Red = 2 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
ID Pipe Sensor
Initial Display
Red = 4 Flashes
Green = Blinks
Meaning = ID Control Error
Red = Blinks
Green = 2 Flashes
Manual Auto Button Error
Initial Display
Red = 4 Flashes
Green = Blinks
Red = Blinks
Green = 4 Flashes
Initial Display
Red = 5 Flashes
Green = Blinks
Meaning = Comms Failure
Red = Blinks
Green = 2 Flashes
Reverse Comms Failure
Initial Display
Red = 5 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
Forward Comms Failure
Initial Display
Red = 6 Flashes
Green = Blinks
Meaning = ID Fan Failure
Red = Blinks
Green = 2 Flashes
Motor locked
Initial Display
Red = 6 Flashes
Green = Blinks
Red = Blinks
Green = 3 Flashes
Motor RPM Incorrect
Initial Display
Red = Blinks
Green = 2 Flashes
Meaning = OD Thermistor Fail
Red = 2 Flashes
Green = Blinks
OD Discharge Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Further Interrogation by Pressing Test Button on Infra Red RCl
Red = 4 Flashes
Green = Blinks
OD Pipe Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 6 Flashes
Green = Blinks
OD Air Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 8 Flashes
Green = Blinks
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 9 Flashes
Green = Blinks
2 Way Valve Sensor Fail
Initial Display
Red = Blinks
Green = 2 Flashes
Red = 10 Flashes
Green = Blinks
3 Way Valve Sensor Fail
Initial Display
Red = Blinks
Green = 3 Flashes
Meaning = Pressure Switch
Red = 2 Flashes
Green = Blinks
Pressure Switch
Initial Display
Red = Blinks
Green = 4 Flashes
IMeaning = D Units Incorrect
Red = 2 Flashes
Green = Blinks
Incorrect Indoor Unit Index
Initial Display
Red = Blinks
Green = 5 Flashes
Meaning = Inverter Failure
Red = 2 Flashes
Green = Blinks
IPM Failure
Initial Display
Red = Blinks
Green = 5 Flashes
Red = 5 Flashes
Green = Blinks
Compressor Failure
MODEL :
MWH008C/CR MWH010C/CR MWH013C/CR
MWH015C/CR MWH020C/CR MWH025C/CR
MWH028C/CR MWH030C/CR MWH040C/CR
MWH050C/CR MWH060C/CR MWH065C/CR
MWH070C/CR
E1 Compressor2 low pressure faulty
E2 Compressor2 high pressure faulty
E3 Compressor2 overload
E4 Indoor coil2 temperature sensor fault
E5 System 2 leaving water temperature2 faulty
F2 Indoor coil1 temperature sensor fault
F4 Return air temperature sensor fault
F6 Communication faulty
F9 Compressor1 refrigerant leak
FE Compressor2 refrigerant leak
H1 Compressor1 overload
H4 Compressor1 high pressure faulty
L1 Compressor1 low pressure faulty
L3 Temperature of water entering too high or low
L4 Water flow switch faulty
L5 System 1 leaving water temperature1 faulty
AUX air conditioner
1. HS(Y) HSA(Y) HSB(Y) HSF (Y) HV(Y) HVA(Y) digital display for the series air-conditioner faults:
Fault source = PG motor feedback is abnormal
Display mode = E4
The display precedence level = 1
Fault source = Plastic temp sensor is abnormal.
Display mode = E1
The display precedence level = 2
Fault source = Copper temp sensor is abnormal (indoor)
Display mode = E3
The display precedence level = 3
Fault source = Copper temp sensor is abnormal (outdoor)
Display mode = E2
The display precedence level = 4
2. H (Except KFR-25G/H) H1 HA HB series faults display:
Display mode = Timing light twinkles 4 times in every 8 seconds
Display mode = Timing light twinkles 1 times in every 8 seconds
Display mode = Timing light twinkles 2 times in every 8 seconds
Display mode = Timing light twinkles 1 times in every 1 seconds
3. H(Y) Model air conditioner fault display:
4. EA EC EM EY EZ EAA EAD EL HS1 HSZ HL1 HLZ P P1 ZZ CZ digital display series air-conditioner faults:
Display mode = E4
Display mode = E1
Display mode = E3
5. All of the other E series except EA EC EM EY EZ EAA EAD:
6. QA QB QD digital display series air-conditioner faults:
Display mode = E4
Display mode = E1
Display mode = E3
Fault source = Over-current oprotection
Display mode = E6
7. QC QQ light display series air-conditioner faults:
Display mode = Timing light twinkles 3 times in every 8 seconds
Display mode = Timing light twinkles 6 times in every 8 seconds
8. Faults display of 18000BTU~24000BTU wall unit series air-conditioner
Non-digital tube displays:
appearance = System turns off
Display mode = Timing light twinkles 8 times in every 8 seconds
appearance = System doesn't turns off
Digital tube displays:
Display mode = E1
Display mode = E3
Display mode = E2
appearance = System doesn't turn off
selam hakan bey DAIKIN marka klimanın(1adet dış ünite 5adet iç üniteyi kumanda eden) ARC412A1 model klima kumandasından klimaları soğuk konumdan sıcak konuma getiremedik mümkünse ARC 412A1 model kullanma klavuzu veya bu tip klimalar hakkındaki bilgilerinizi bizlerle paylaşırsanız seviniriz şimdiden paylaşımlarınız için teşekkür ederim
Arkadaşlar;
Fabrikada 2adet Alarko Salon Tipi klima ısıtma konumuna geldiğinde yaklaşık 3dk bekledikten sonra E6 hatası veriyor.
E6>>Evap. Termistor Diagnosis
klima evaparatörü talebi bulunmadan önce sizlere danışmak istedim..evaparatörü almadan önce müdahale edebileceğim bir nokta varmıdır? hata sinyalini gönderen kabloyu açık yada kapalı devre yaparak makine kandırma yoluna girersem,sonuçları neler olabilir?
Alarko APH-1259 Salon Tipi Klimaların Hata kodları
E1 : Comp.Protector Diagnosis
E2 : Room Thermistor Diagnosis
E3 : Key status Diagnosis
E4 : Defrost timer Dianosis
E6 : Evap. thermistor Diagnosis
twenine
