t6963c-240x128-ccs cod
perçin
17 Ağu 2009
ANKARA_OSTİM
#include "C:\Documents and Settings\perçin\Belgelerim\ccs c cod\240_128_glcd.h"
#include <t6963c_2.c> //
#include <graphics.c>
#fuses NOWDT,HS, NOPUT, PROTECT, BROWNOUT, NOLVP, NOCPD, NOWRT, NODEBUG
#use delay(clock=20000000)
int adc = 0, adc_old =0;
#inline
void logo()
char giris1[] = "DENEME";
char giris2[] = "IRFAN PERCIN";
char giris3[] = "irfanpercin........";
glcd_text57(12,12,giris2, 3, ON);
glcd_text57(62,45,giris1, 3, ON);
delay_ms(1000);
glcd_box(10,10,230,80, ON); //dolgu koyu renk
glcd_text57(12, 12,giris2, 3, Off);
glcd_text57(62,45,giris1, 3, Off);
delay_ms(1000);
//glcd_box(10,10,230,80, Off); //dolgu açık renk
glcd_square(10,95,220,110, on); // bar
glcd_text57(42, 98,giris3, 1, ON);
glcd_pixel(239,127,on); //
glcd_pixel(1,127,on); //
glcd_pixel(1,1,on); // köşelere tek nota pixel test
glcd_pixel(239,1,on); //
#inline
void adcd ()
int digit[4];
set_adc_channel(1);
adc = read_adc();
// clear_screen(); //sadece adc gör
for(;;)
glcd_text57(100,118, digit,1, ON);
adc = read_adc();
if(adc != adc_old)
glcd_text57(100, 118, digit,1, OFF);
adc_old = adc;
sprintf(digit, "%03u",adc);
glcd_square(95,115,120,127, on);
#inline
void main()
setup_adc( ADC_CLOCK_INTERNAL);
setup_adc_ports( AN0 );
delay_ms(10);
set_tris_c(0x00); // graphic lcd control lines all output
glcd_init(); //Initialization
glcd_WriteByte(2, (LCDModeSet|LCDMode_XOR)); //XOR-Mode ..................( ??????)
glcd_WriteByte(1, (LCDDispMode|LCDDisp_TXT|LCDDisp_GRH)); //Text and Graphic-Mode
delay_ms(1);
logo();
adcd();
driwer t6963c-2
//// Connections are as follows: ////
//// /CE - - C3 ////
//// /WR - - C4 ////
//// /RD - - C5 ////
//// C/D - - C6 ////
//// /RST- - C7 ////
//// DATA0-7 - - PORTD0-7 ////
//// LCD's FS is tied low (FS = 0 is 8x8 font) ////
#ifndef GLCD_COL
#define GLCD_COL 240 // Used for text wrapping by glcd_text57 function and sanity check
#endif
#ifndef GLCD_ROW
#define GLCD_ROW 128 // Used for text wrapping by glcd_text57 function and sanity check
#endif
#define set_tris_lcd(x) set_tris_d(x)
#define ON 1
#define OFF 0
#define YES 1
#define NO 0
//TRIS DataBus=x, note:control bus (PORTC) always outputs
const int16 TextHome=0x0EE2; //0x0780 (240*64)/8=1920-->0x0780 ( **240*127 için 3810=0EE2)
const int8 TextArea=0x003C; //(orjinali=0x001E how many bytes before a new line (30 bytes))
const int16 GraphicsHome=0x0000;
const int8 GraphicsArea=0x003c; //(orjinali=0x001E how many bytes before a new line (30 bytes) (60 byt için 003c))
const int8 AutoModeWrite = 0xB0; //DataAutoWrite
//const int8 AutoModeRead = 0xB1; //DataAutoRead
const int8 AutoModeReset = 0xB2; //Auto reset
const int8 LCDModeSet = 0x80; // send this OR'd with the following
//const int8 LCDMode_OR = 0b0000;
const int8 LCDMode_XOR = 0b0001;
//const int8 LCDMode_AND = 0b0010; //0b0010
// const int8 LCDMode_TA = 0b0100; // TEXT ATTRIBUTE mode.
const int8 LCDMode_RAM = 0b1000; // 1=CG RAM, 0=internal CG ROM
//const int8 LCDSetCursorPtr = 0x21; // cursor address
// const int8 LCDSetCursorSize = 0xA0; // 1 line cursor
const int8 LCDDispMode = 0x90; // send this OR'd with the following
//const int8 LCDDisp_BLK = 0b0011; //0b0011 Blink Cursor
// const int8 LCDDisp_CUR = 0b0010; // Add Cursor
const int8 LCDDisp_TXT = 0b0100; //Text-OK,Graphic-NG
const int8 LCDDisp_GRH = 0b1000; //Text-NG,Graphic-OK
const int8 LCDBitSet = 0xF8;
const int8 LCDBitReset = 0xF0;
struct lcd_pin_def //Struct type bitfield
int1 unused1 :1; // C0
int1 unused2 :1; // C1
int1 unused3 :1; // C2
int1 ce :1; // C3 Chip enable active low
int1 w_bar :1; // C4 Write bar active low
int1 r_bar :1; // C5 Read bar active low
int1 cd :1; // C6 Command/Data BAR 1=command 0=data
int1 reset_bar :1; // C7 Reset active low
int8 data :8; // PortD=Data bus(address=8)
struct lcd_pin_def LCD;
#byte LCD = 7 // portC address=7 on 16F877A
//Prototyping
int glcd_ReadByte(void);
void glcd_WriteByte(int1 cd, int data);
void glcd_WriteByteAuto(int data);
void glcd_WriteCmd2(int16 data, int cmd);
void glcd_WriteCmd1(int data, int cmd);
void glcd_gotoxy(int x, int y, int1 text);
void glcd_init(void)
int16 counter;
set_tris_lcd(0x00); //TRIS DATA bus(PORT D),note:control bus always outputs
LCD.ce=0; //INITIAL STATES OF CONTROL PINS
LCD.w_bar=1; //
LCD.r_bar=1; //
LCD.cd=1; // command
LCD.reset_bar=0; // perform a reset
delay_us(10); // delay for a reset
LCD.reset_bar = 1; // run
// Set up the graphics and text areas
glcd_WriteCmd2(TextHome, 0x40); //TextHomeAddress Set
glcd_WriteCmd2(TextArea, 0x41); //TextArea column Set
glcd_WriteCmd2(GraphicsHome, 0x42); //GraphicHomeAddress Set
glcd_WriteCmd2(GraphicsArea, 0x43); //GraphicArea column Set
// set AddressPointer to 0
glcd_WriteCmd2(0x0000, 0x24); //Set AddressPointer to 0
// Clear all RAM of LCD (8k)
glcd_WriteByte(1, AutoModeWrite); //Set Data Auto Write
for (counter = 0; counter < 0x1fff; counter++) //0x1fff=8191 bytes
glcd_WriteByteAuto(0); // sıfır ile her şeyi doldurmak
glcd_WriteByte(1, AutoModeReset);
void glcd_WriteByte(int1 cd, int data) //Normal "modunda komut veya veri" olarak PORTD'ye yazın.
int status = 0, temp = 0;
set_tris_lcd(0xff); // All inputs
LCD.ce = 1;
LCD.w_bar = 1;
LCD.r_bar= 1;
LCD.cd = 1;//defaults
while (status != 0x03) { // is LCD busy?
LCD.r_bar= 0;
LCD.ce = 0; //After 150ns read the data on D0-7
#asm nop #endasm
temp = LCD.data;
LCD.ce = 1;
LCD.r_bar = 1;
status = temp & 0x03; //Masking
set_tris_lcd(0x00); // All outputs
LCD.cd = cd; // Command/Data bar (1=command 0=data)
LCD.data = data; // Put data on data bus
LCD.ce = 0;
LCD.r_bar = 1; // not read
LCD.w_bar = 0; // write
LCD.ce = 1;
LCD.w_bar = 1; // release
void glcd_WriteByteAuto(int data) //Write PORTD as data in "Auto" mode.
int status = 0, temp = 0; // WHEN Auto mode,the status bits ARE DIFFERENT BITS THAN NORMAL MODE
LCD.ce = 1;
LCD.w_bar = 1;
LCD.r_bar = 1;
LCD.cd = 1; // defaults
while (status != 0x08) { // is LCD busy? Checking STA3!
LCD.r_bar = 0;
LCD.ce =0; //After 150ns read the data on D0-7
#asm nop #endasm
temp = LCD.data;
LCD.ce = 1;
LCD.r_bar = 1;
status = temp & 0x08; //Masking
LCD.cd = 0; // This is always data
LCD.ce = 0;
LCD.ce = 1;
glcd_WriteByte(0, data);
glcd_WriteByte(1, cmd);
glcd_WriteByte(0, data & 0xff); //masking,LSB Set
glcd_WriteByte(0, data>>8); //shift right 8bir,MSB Set
int data = 0, status = 0, temp = 0;
LCD.ce = 1;
LCD.w_bar = 1;
LCD.r_bar = 1;
#asm nop #endasm
LCD.r_bar = 0;
LCD.ce = 0;
temp = LCD.data;
LCD.ce = 1;
LCD.r_bar = 1;
LCD.cd = 0; // Command/Data bar
LCD.ce = 0;
LCD.r_bar = 0; // read
#asm nop #endasm // THIS PAUSE IS VERY NESSESARY !!!//
data = LCD.data;
LCD.r_bar = 1;
LCD.ce = 1;
LCD.cd = 1;
return data; // Return the read data
void glcd_putc(char c)
glcd_WriteCmd1(c - 0x20, 0xc0); //c-0x20=Transfer from Ascii Code, Data Write UP.
void glcd_gotoxy(int x, int y, int1 text) { // sets memory location to screen location x, y
// location 1,1 is upper left corner;
// text = 1 (text area), text = 0 (graphics area)
int16 location, home;
int line;
if (!text) {
home = GraphicsHome;
line = GraphicsArea;
else {
home = TextHome;
line = TextArea;
location = home + (((int16)y - 1) * line) + x - 1;
glcd_WriteCmd2(location, 0x24);
Void clear_screen(void){ //very simular to the glcd_init(void)
int16 counter;
// set address to 0
glcd_WriteByteAuto(0); // fill everything with zeros
unsigned int8 i; //General Purpouse variable
// glcd_pixel8(x,y,px8) sets 8 pixels in line.
void glcd_pixel8(unsigned int8 x, unsigned int8 y, int8 pixel8){
unsigned int8 x_H;
x_H = (x / 8);
glcd_gotoxy(x_H+1,y,0);
glcd_WriteCmd1(pixel8,0xc0); //Write data and increament
// glcd_pixel(x,y,c) sets pixel x,y with c color // tek nota için
void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 c){
unsigned int8 x_H;
unsigned int8 x_L=0;
x_H = (x / 8);
x_L = 7 - (x - 8*x_H);
if(c){
glcd_WriteCmd1(1,(LCDBitSet|x_L));
} else {
glcd_WriteCmd1(1,(LCDBitReset|x_L));
// glcd_line(x0,y0, x1,y1, c) puts line from (x0, y0) to (x1, y1) with c color
//#separate
void glcd_line(signed int16 x0, signed int16 y0,
signed int16 x1, signed int16 y1 , int1 c){
int16 x;
int16 y;
unsigned int16 n;
int1 m_case;
x=abs(x1-x0);
y=abs(y1-y0);
if (y > x){
n=(y1-y0);
m_case=1;
} else {
n=(x1-x0);
m_case=0;
for(i=0 ; i<=n ; i++){
if (m_case){
y=i + y0;
x=(y*(x1-x0))/(y1-y0) + x0;
} else {
x=i + x0;
y=(x*(y1-y0))/(x1-x0) + y0;
glcd_pixel(x, y,c);
// glcd_square(x0,y0,x1,y1, c) sets square .............................. kare yapmak için
void glcd_square( unsigned int8 x0, unsigned int8 y0,
unsigned int8 x1, unsigned int8 y1 , int1 c)
glcd_line(x0,y0, x1,y0, c);
glcd_line(x1,y0, x1,y1, c);
glcd_line(x0,y1, x1,y1, c);
glcd_line(x0,y0, x0,y1, c);
// glcd_box(x0,y0,x1,y1, c)..............................................dolgu yapmak için
void glcd_box( unsigned int8 x0, unsigned int8 y0,
unsigned int8 x;
unsigned int8 y;
for(y=y0; y<=y1;y++)
for(x=x0; x<=x1;x++)
if((!(x%8)) && ((x1-x)>8))
glcd_pixel8(x,y,0xFF*c); //Aynı zamanda 8 piksel yazmak için
x +=7 ;
} else {
glcd_pixel(x,y,c);
//glcd_image8 (*Pic, x, y, size_x, size_y)..............................resim basmak için
void glcd_image8(int8 *pic_px, unsigned int8 x, unsigned int8 y,
unsigned int8 size_x, unsigned int8 size_y)
unsigned int8 px_y;
unsigned int8 px_x;
unsigned int8 px=0;
for(px_y=y; px_y<(y+size_y); px_y++)
for(px_x=x; px_x<(x+size_x); px_x+=8)
glcd_pixel8(px_x, px_y, *(pic_px+px));
px+=1;
arkadaşlar böyle bir programı veren kişiye bir teşekkür etmek bukadar zor mu..
TEŞEKKÜRLER İRFAN ABİİ...
Hocam paylaşımın için teşekkurler. yazıyı nasıl çevirebiliriz şöyleki yatayda veya dikeyde yazıyı nasıl çevirebiliriz?
Teşekkür ederim, gerçekten işime yarayacak gibi görünüyor...
S.A.
@perçin tüm dosyanı driverleri ile birlikte koyarsan sevinirim. 18f452 ye göre derledim hep graphics.c de hata verdi. kolay gelsin
S.A.
aynı hata bendede vermekte ilgilenirseniz sevinirim...
t6963c_2.c zaten driver dosyası (driwer t6963c-2 başlayan bölümü pic c drives doyyasına eklemek gerekiyor..bu bölüm cod bölümüne dahil değildir) pic c drivers'e t6963c-2'yi eklemek için ordaki dosyalardan herhangi birini kopyalayıp içini boşalttıktansonra t6963c-2'yi buraya kopyalamak yeterlidir dosya ismide (t6963c-2) olacak... "graphics.c" hatası içinse : enbaşa önce" #include <t6963c.c>" sonra "#include <graphics.c>"yazmalısınız yoksa hata verir.
t6963c_2.c dosyasını nereden indirebilirim hiçbiryerde bulamadımda,şimdiden teşekkürler...
t6963c_2.c dosyası : " /* " driwer t6963c-2 başlayıp " */ " ile biten bölüm sadece orada belirtme ifadesi olan driwer t6963c-2'yi
sileceksiniz arkadaşlar zaten gerekli olan herşey var sadece çalıştıracaksınız,kolaygelsin.
eemir
