Windows 11 desteklemeyen pc ye nasıl yüklenir
11 Haz 2022
selam benim bilgisayarımda TPM çipi bulunmadığından dolayı win 11 kullanamıyorum yardımcı olursanız çok teşekkür ederim
If your PC does not meet the system requirements for Windows 11, you can't install it directly on your computer. However, there are a few options you can try:
  1. Upgrade to Windows 10: If your PC is running an older version of Windows, such as Windows 7 or 8.1, you can upgrade to Windows 10. Windows 10 has lower system requirements than Windows 11 and should work on most PCs that can't run Windows 11.
  2. Install a lightweight operating system: You can install a lightweight operating system, such as Linux, that can run on older hardware. Linux is free and has many different distributions to choose from, such as Ubuntu, Mint, and Fedora.
  3. Upgrade your hardware: If you want to use Windows 11, you may need to upgrade your hardware. The system requirements for Windows 11 include a modern processor, at lead 4 GB of RAM, and a DirectX 12 compatible graphics card.
Note: It's important to ensure your computer's hardware meets the system requirements for any operating system you plan to install to ensure it will work properly.
lojis
