-100 ve -150 derece arası soğutma
Size pm attım @deltas
Thank everyone for the valuable suggestions. Currently our company builds 2-stage cascade systems. Normally they are used in vacuum chamber and testing chamber. Two ¼ HP compressors are used. The system can reach -100 degree Celsius. We do have some experience to design and manufacture two-stage cascade systems.
Recently, a customer has an application which needs the temperature goes down to -130 degree Celsius. We plan to develop a 3-stage system based on our current 2-stage systems. Following is an outline of my design. Please give me your opinions:
Three ¼ HP compressors are used. For two stage systems, it is a good choice to use 2 compressors having the same power. I am not sure if this principle still works for three stage systems.
First Stage: condensing temperature: 35C; evaporating temperature: -30C. Refrigerant: R404A or ISCEON89. A fined tube air cooled condenser is used.
Second Stage: condensing temperature: -25C; evaporating temperature: -75C. Refrigerant: R23 or (R508 + R14).
Third Stage: condensing temperature: -70C; evaporating temperature: -140C. Refrigerant: R14.
By my rough calculation, if the refrigerants are selected as above, the condensing and evaporating temperatures in each stage should be the values I give. But I am not sure if the system is optimal in these conditions. It is very difficult to get the optimal solution just by calculation. I will adjust the system based on test result.
Plate heat exchangers (WTT) are used between first and second stage, and second and third stage. Five degree temperature difference is enough for efficient heat transfer.
The metering device in first stage is a thermal expansion valve. Capillary tubes are used in second and third stages.
Cylinders are used as fade-out drums in second and third stages. They are place in the low side between the evaporator and the compressor. The size of the tank will be determined by experiments. There is no harm that the fade-out drum is a little bit oversize. Is it correct?
Coalescent oil separators (Temprite) are used in second and third stages for oil separation.
The principle of cascade system is very simple. But to select parts and build it is very challenge. I start to test the performance of the first and second stages, and hope it can provide about 300 ~ 350 watts cooling capacity at -80C for the third stage.
Now I still have trouble to find a suitable compressor for the third stage. And I also need to confirm that R14 is the best choice for the third stage. Any information and suggestions about the compressor and the refrigerant for the third stage are welcome.
Ken, Could you give me more information about the consultant you talked about? If he is really very professional in cascade system design, and if we really have trouble to develop it by ourselves, maybe my boss is willing to pay him for his help.
Thanks again. I am willing to share all the information with you, and will report you guys my work on this project regularly.
Burada görüştüğüm bi arkadaş bunları gönderdi.
Belirttiğiniz sistem 3 kademeli kaskat. Kullanilan son akışkan R14. Donma sıcaklığı -184. Calisirsa kullanilabilinir. Ancak R14 ve uygun kompresör Türkiye piyasasında varmıdır? Bunu Serkan hocam daha iyi bilir.
Yazdığınız gazlar hakkında bir yorum yapamıyorum. Diğer mesajimda belirttiğim gibi bir uzman yardımı ile test etmelisiniz.
ve bugün araştırmalarımı sonlandırdım arkadaşlar. ne yazık ki böyle bir ülkede bu konuda hiçbir ar-ge yapılmamış. ve yapmayı da düşünmüyorlar.(maddi olarak o kadar gücüm olmadığı için maalesef ben de yapamıyorum.)
bir firma buldum gaz hakkında. onlar da cihazı yurtdışına istediler. firmanın ilgilisi hazıra alıştık gibi cümleler kurunca artık kararımı verdim bu konuda.
yapabilirsem azot ile, yapamazsam kader utansın yani ne diyim :) (azotu saklayacak kap 3600 € + kdv, 60L azotu 25 gün tutabiliyor)
herkese iyi çalışmalar. @deltas ve @by lent ve serkan_48 arkadaşlarıma da katkı ve ilgilerinden dolayı çok çok teşekkür ederim.
merhaba. ben cihazın kullanım alanını merak ettim, kırık telefon ekranını koyuyor sonra ?
telefon için kullanıldığını gördüm ama benim kullanım amacım farklı. bana 50 ye 50 bi alanı soğutması gerekli. o sizin bahsettiğiniz telefon için olan 28 e 19 mu öyle birşeydi @vecivicivokke
Merhaba @vecivicivokke ,
Elektronik mühendisi arkadaşın söylediği: " bu tur ekranlar çok katmanlı. Kırılan üst tabaka, -140 ile -150 derece arasında ara tabaka dondurularak ekrandan ayrılması sağlanıyor. Sonra sağlam bir katman üzerine montajlaniyor. Bu işlem esnasında alt tabakalar ve elektronik bağlantılar hasar görmediği taktirde eski işlevini görüyor. Özellikle iPhone'larin yedek parçaları pahalı olduğundan bu işlem maliyeti düşürüyor. Bu işlem işçilik dahil 100 TL civarına mal olur."
Bunlar bana aktarılan bilgiler. Ben elektronikten anlamam. @demonblade , ne amaçla kullanacak birşey diyemem. Düşük sıcaklığın birçok kullanım alanı mevcut. Ancak genelde çok özel alanlarda kullanıldığından Türkiye'deki firmalar bu işe pek fazla girmiyorlar. Pazarı büyük değil. Yapsalar dahi pazarı dar olduğundan çok yüksek fiyata satarlar. Arz-talep olayı.
Fizibilitesi yapilacak. Eğer uygun görülürse inceleyecegiz. Zaten şu anda sade böyle bişey düşünmüyoruz. İşi biraz daha komplike hale getirdik. Öyle işte. :)
İyi çalışmalar..
Mustii54
