Led devresi
çaıştırdığına sevindim. uln2003 bağlantılarında 8 numara gnd. 9 numara mutlaka +12 ye. zaten nbatman arkadaş söylemiş.
10mhz yerine 12mhz takabilirsin fakat programdan ayarlmalısın. 18pf lar mutaka 18pf olarak takılmalı.
programmerdan xt yerine hs yi seçmelisin. 4mhz üstü high speed olarak kabul edilir.
bu arada elinde proton3 ide varsa değiştirmen gereken yerleri söyleyim yoksa ben değiştiriyim.
:100000009D28A9002530A1002630A20066200319F2
:100010001210031D1214FC3E031C921003189214BC
:10002000A030A1002530A2002630A500A60112189C
:1000300037209218372068202103831692008312FC
:100040002108A3002208A4002008A700A800200F70
:10005000A8018220260895000C309700A51B971652
:10006000251B17168316061183121215982838209F
:100070000310A50CA20CA10C080083178001840AB0
:10008000FF3E031D3E289828A401A300FF30A307CC
:10009000031CA407031C98280330A200E53052205B
:1000A0004628A201F63EA100A209031C5D28FE30ED
:1000B0000000A10703185828A1070000A20F572825
:1000C000000021186328211865280800A601A50151
:1000D0001030A700220DA50DA60D2308A5022408A7
:1000E000031C240FA60203187C282308A507240854
:1000F0000318240FA6070310A10DA20DA70B6A2851
:10010000210898281030AA00A201A101A80CA70C70
:10011000031C90282308A10724080318240FA20712
:10012000A20CA10CA60CA50CAA0B862825089828C1
:100130008313831203130000080007309F00073069
:100140009F0083160610861006118611051483126F
:1001500006108610061186112030840060303E2083
:10016000A030840050303E202030840030303D20CC
:1001700064304420BB280518ED280A3044200130A3
:1001800005180301AB0001302E1803012B050319DC
:10019000ED282E142D08AC00FB302C020318E028AB
:1001A00019304420051CD528E0282C08A0000B306D
:1001B000A400B830A30000300120AC0A031DCC28F5
:1001C0002C08AD0006140330A400E8304520861446
:1001D0000330A400E83045200615051C22290A300A
:1001E0004420030105180130AB0003012E18013033
:1001F0002B05031922292E102D08AC00AC08031979
:100200001229193044200518062912292C08A000AB
:100210000B30A400B830A300003001200130AC0244
:100220000318FE282C08AD00A0010B30A400B83044
:10023000A300003001200330A400E8304520061060
:0A0240008610061105304420BB288B
:02400E00223F4F
:00000001FF
buradakileri olduğu gibi kopyalayıp sendeki hex dosyasına yapıştırıp yeniden yükle :) sıkıtırıp mail atmaya üşendim
Hocam teşşekkür ederim. PIC in +5v ve gnd bağlantılarını yaptım uln2003a nın gnd bağlantısını yapmayı düşünemedim :) 12MHZ kullanırsam programda xtal kısmını 12 yapmam gerekir değilmi? başka bir değişikllik yapmam gerekir mi? zamanlama için nereleri değiştirmem gerekir söylerseniz sevinirim biraz da yazılım olayını öğrenmek istiyorum oz yüzden soruyorum. Mesela proton da bas dosyasını açıyorum HPWM 0,duty,2000 kısmındaki 2000 olan değeri 4000 yapıyorum aralardaki 200 olan milisaniyeleri arttırıyorum compile diyorum sonra bas dosyasının olduğu yerde oluşan hex dosyasını PIC e yüklüyorum hiçbir değişiklik olmuyor.
yukarıdaki hex dosyasını denersen ben değiştirdim zaten.
hpwm deki 2000 değeriyle oynama o pwm frekansı zamanla alakası yok. for next döngüsü içindeki 10ms olan değerleri 20-30-40 diye değiştirierek yavaşlatabilirsin. yada düşürerek hızlandırabilirsin. diğer led için olan 200ms leride 1000ms yaparsan 1sn arayla yanarlar.
Hocam zaten gönderdiğiniz hex dosyası zamanlaması tam istediğim gibi olmuş. birtek kontak ucuna 12 volt verdiğimde ilk ledler biraz yanıp ondan sonra canlanıyor ben 0 dan başlayarak canlansın istiyorum böyle yapmanın yolu var mı? birde kontak ucuna 12 volt verince devrenin 1 saniye sonra başlamasını sağlayabilir miyiz?
:1001700064304420BB280518EE280330A400E83082
:100180004520013005180301AB0001302E18030192
:100190002B050319EE282E14AC01FB302C0203189A
:1001A000E12819304420051CD628E1282C08A0009D
:1001B0000B30A400B830A30000300120AC0A031DAE
:1001C000CD282C08AD0006140330A400E8304520EB
:1001D00086140330A400E83045200615051C2329A9
:1001E0000A304420030105180130AB0003012E182A
:1001F00001302B05031923292E102D08AC00AC0863
:1002000003191329193044200518072913292C082C
:10021000A0000B30A400B830A30000300120013052
:10022000AC020318FF282C08AD00A0010B30A4007D
:10023000B830A300003001200330A400E83045208E
:0C02400006108610061105304420BB2873
:02400E00223F4F
:00000001FF
birde bunu yükleyelim
Hocam bu son verdiğinizde zaman gecikmesi tamam kontak ucuna 12 volt verince 1 saniye sonra devre çalışıyor. fakat yine ledler 0 dan başlayıp canlanmıyor biraz yanıp ondan sonra canlanıyor.
ledlere bağlı dirençler kç ohm?
:1001B0000330A400E830A30000300120AC0A031D86
:10021000A0000330A400E830A3000030012001302A
:02400E00223F4F
:00000001FF
pwm frekansını 1khz yaptım bir daha deniyelim. %1 den başlatıyorum buna rağmen ledlerin yandığı görülüyosa dirençler 330 ohm yapalım
Dtsbulut
