En iyi sekonder koruma rolesi hangisi?
Siemens
6MD61x I / O Box
> 6MD63x Medium Voltage Bay Unit
> 6MD662-664 Bay Control Unit
> 6MD665 Bay Processing Unit
> 7PA2 / 3 Relays for high responsibility applications
> 7RE28x Voltage Balance Relay
> 7RW600 Voltage- / Frequency Protection
> 7SA522 Distance Protection
> 7SA6xx Distance Protection and Control
> 7SD52x / 53x Differential Protection for 2 - 6 Line-Terminals with Distance Protection
> 7SD600 Line Differential Protection for one pilot wire pair
> 7SD610 Universal Two-Terminal Differential Protection
> 7SJ45 easy Numerical overcurrent protection
> 7SJ46 easy Numerical overcurrent protection
> 7SJ600 Overcurrent, Motor and Overload Relay
> 7SJ601 Overcurrent, Motor and Overload Relay
> 7SJ602 Overcurrent and Overload Relay
> 7SJ61x Multifunction Protection
> 7SJ62x Multifunction Protection
> 7SJ63x Multifunction Protection
> 7SJ64x Multifunction Protection with Synchro Function
> 7SJ80x Multifunction Protection Relay
> 7SK80x Motor Protection Relay
> 7SN600 Transient Earth-Fault Relay
> 7SS52x Distributed Busbar and Circuit-Breaker Failure Protection Relay
> 7SS60x Centralized Numerical Busbar Protection
> 7ST61x / 63x Overhead Contact-Line Protection for AC Traction Power Supply
> 7SV600 Numerical Circuit–Breaker Failure Protection Relay
> 7TS15 / 16 Annunciation Relay
> 7UM61x Multifunction Generator Protection Relay
> 7UM62x Multifunction Generator Protection Relay
> 7UT612 Multiple function protection for two winding transformers
> 7UT613 / 63x Differential protection for transformers (2 - 5 windings / ends)
> 7UW50x Tripping Matrix
> 7VE6xx Multifunction Paralleling Device
> 7VH60x High Impedance Differential Relay
> 7VK61x Breaker Management Relay
> 7VP15x Portable Test System
> 7XV75x Test Switch
> PHO:32x Test disconnect terminal UTME 6-MP and test disconnect plug SMP
Archive > Actual devices
> 7SA510 Distance Protection
> 7SA511 Distance Protection
> 7SA513 Line Protection Relay
> 7SA518 Overhead Contact-Line Protection Relay
> 7SA519 Overhead Contact-Line Protection Relay
> 7SD502 Line Differential Protection with two Pilot-Wires
> 7SD503 Line Differential Protection with three Pilot-Wires
> 7SD511 Current Comparison Protection Relay
> 7SD512 Current Comparison Protection Relay with AR
> 7SJ50x Overcurrent-Time Protection Relay
> 7SJ511 Overcurrent-Time Protection Relay
> 7SJ512 Overcurrent-Time Protection Relay
> 7SJ531 Line and Motor Protection
> 7SJ551 Multi-Function Protection Relay
> 7SS50x Busbar / Circuit-Breaker Failure Protection Relay
> 7UT51x Differential Protection Relay
> 7SV512 Numerical Circuit–Breaker Failure Protection Relay
> 7SV73x Power Supply Unit
> 7UM511 Generator Protection
> 7UM512 Generator Protection Relay
> 7UM515 Generator Protection Relay
> 7UM516 Generator Protection Relay
> 7VE51x Synchronizing Unit
> 7VH80x High Impedance Differential Relay (1 Pole)
> 7VH83x High Impedance Differential Relay (3 Pole)
> 7VK512 Auto–Reclose Relay
SIPROTEC - Siemens
Siemens de yazılım ücretlidir hemen hemen tüm rölelere DİGSİ4 ile kontrol edilmektedir. DİGSİ4 DEMO olarak siemensin sitesinde var.
SCHNEİDER
Products and Services-Schneider Electric
Sepam serie 10
Overcurrent and earth fault relay for basic protection of feeders and distribution transformers
Sepam serie 20
Digital protection relays for current or voltage protection, for any distribution system
Sepam serie 40
Sepam serie 80
Sepam serie 100
Additional protection and control modules
Yazılım kendi sitesinden indiriliyor.SEPAM Setting Software SFT2841 V11.2
11 Oct 2010 yayınlanmış,tümrölelere bu yazılım ile erişiliyor.
GENERAL ELEKTRİK (GE)
GE Digital Energy - Protection & Control
Rölelere göre yazılımların hepsi free olarak kendi sitesinden indirilir.
UR serisi röleler T60,M60,D60,F35 ve Bay Control olan F650 rölesi Diger firmaların rölelerine göre kullanıcı dostu rölelerdir.Yazılımlarını kullanmak cok kolaydır. Hepsinde RJ45 veya fiber,önkısımda RS232 bağlantı portu vardır.F650 rölesine Boot ve firmware yi firmaya bağımlı kalmadan free olarak değiştire bilirsiniz.F650 rölesini Fider de,diferansiyel istemeyen küçük güçlü motor da,trafo da kullanabilirsiniz.Eternet cıkışı sayesinde kurdugunuz network alt yapısı üzerinden kilometrelerce uzaklardan röleye erişe bilirsiniz.Röle icerisinde web server özelliği ile internet exployer"e rölenin İP'sini yazarak akım gerilim ve içerisindeki OSC kayıtlarını PC'nize alırsınız.
Röleler Türkiyeden temin edilmektedir.İlgilenen arkadaşlara yardımcı olurum.
239 Motor Protection
269Plus Motor Protection
3 Series Family
339 Motor Protection
345 Transformer Protection
350 Feeder Protection
369 Motor Protection
469 Motor Protection
489 Generator Protection
515 Test Switch
735/737 Feeder Relay
745 Transformer Protection
750/760 Feeder Protection
ALPS Line Protection
B30 Bus Protection
B90 Bus Protection
BDD Relay
BUS1000/2000 Protection
C30 Controller
C60 Breaker Protection
C70 Cap. Bank Protection
C90Plus Controller
CEB Relay
CEH Relay
CEX Relay
CEY Relay
CEYG Relay
CFD Relay
CFVB Relay
CHC Relay
CIO Remote Module
DART
D20/D200 Substation Controllers
D25 Substation Controller
D30 Line Protection
D400 Substation Data Gateway
D60 Line Protection
D90Plus Line Distance Protection
DBF Breaker Failure
DBT Breaker Supervision
DDFR Fault Recorder
DDS Distribution System
DFF Frequency Relay
DGP Generator Protection
DGT Gen. Trip Control
DIAC Overcurrent Protection
DLPD Line Protection
DMS Multifunction System
DRS Reclosing System
DTP-B Transformer Prot.
DTR Tap Changer
EPM 1000 Meter
EPM 2000 Meter
EPM 4000 Meter
EPM 5200 Meter
EPM 5300 Meter
EPM 5350 Meter
EPM 6000 Meter
EPM 9450 Meter
EPM 9650 Meter
EPM 9800 Meter
EPM Family
ET-16 LED
ET-16 Lamp
F35 Feeder Protection
F60 Feeder Protection
F650 Bay Controller
FM2 Feeder Manager
G30 Generator Protection
G60 Generator Protection
G650 Generator Protection
GCX Relay
GCY Relay
GGP Relay
GSY Relay
GXS Relay
HardFiber System
HAA Relay
HEA Relay
HFA Relay
HFC Relay
HGA Relay
HGA18 Relay
HID Differential Module
HMA Relay
HSA Relay
IAC Relay
IAV Relay
IBC Relay
IBCG Relay
iBox Serial Substation Controller
ICR Relay
ICW Relay
IFC Relay
IFCV Relay
IFV Relay
IJC Relay
IJD Relay
IJS Relay
JBC/JBCG/JBCV Relay
L30 Line Protection
L60 Line Protection
L90 Line Protection
LM10 Motor Protection
LPS Line Protection
LPS-O Line Protection
M Family
M60 Motor Protection
MFF Frequency Relay
MGC Relay
MIB Bus Differential
MIC Overcurrent Relay
MID DDS Family
MIF Feeder Relay
MIF II Feeder Relay
MIG Machine Protection
MIG II Generator Protection
MIN Ground Protection
MIN II Ground Protection
MIV Voltage/Freq. Relay
MIV II Voltage/Freq. Relay
MIW Directional Relay
MIW II Directional Relay
MLJ Relay
MM2 Motor Protection
MM3 Motor Protection
MM200 Motor Protection
MM300 Motor Protection
MOV Multifunction Relay
MPM Motor Protection Meter
MultiLink Family
ML600 Ethernet Switch
ML800 Ethernet Switch
ML1200 Ethernet Switch
ML1600 Ethernet Switch
ML2400 Ethernet Switch
MultiNet1000 WAN Router
MultiNet Serial Converter
MultiNet4 Serial Server
N60 Network Protection
NAA Relay
NBV Relay
NGA Relay
NGV Relay
PJC Relay
PJG Relay
PJV Relay
PPQM Meter
PQM Meter
PQMII Meter
PVD Relay
RDB86 Relay
SAM Relay
SBC Relay
SBD Relay
SCA Relay
SFF Relay
SGC Relay
SLJ Relay
SMOR-B Feeder Protection
SPM Synchronous Motor Control
STD Relay
STV Relay
T35 Transformer Protection
T60 Transformer Protection
TCCV Relay
TCW Relay
TOV Relay
W650 Wind Generator Protection
ABB
ABB Protection and Control (Distribution) - Power Protection & Automation Products
ABB 'nin rölelerinden REF542 PLUS rölesinde lojik diaframa girdiğinde enerjili noktaları canlandırma yapması güzeldi.
Yazılım operatör modunda kendi sitesinden indiriliyor.
En son calıştıgım 380kV Şalt sahasında ki rölele ABB idi.
34500kV kısmında REF542 PLUS'lar kullanıldı.
YG kısmındada yeni çıkan 670 seri röleler kullanıldı.
Geniş bilgi isteyen arkadaşlara vere bilirim.
Bu röleleri tercih eden arkadaşlara yardımcı olurum.
KONTROL RÖLESİ
REC670
FİDER kORUMA RÖLELERİ
REF541,543,545,610,615,630,542 PLUS,550
REJ603 REX521
DPU200R
HAT KORUMAÖLESİ
RED615
RED670
GENERATÖR KORUMA
REK510
REG670
MOTOR KORUMA
REM543,545,610,615
TRAFO KORUMA
RET541,543,545,615,630,670
BARA KORUMA
REB615,670
MESAFE KORUMA
REL670
AREVA,VAMP ve diğer röleleride başka sefere yazarım.
İYİ GECELER............
bu soru hangisi en iyi yerine hangisi kötü diye sorulmalı.
kötü olan:? (işareti olarak gösteriyorum malum mahkemelik işler) (çok yaygın olan bir koruma rölesi)
bulunduğum dağıtım şirketinde analog ( gemta, entes) dijital (pnc, mcr,thytronic, siemens, abb) var. ? dışındakilerde bir birlerine göre avantajları olabildiği gibi benim gözümde pnc üstüne röle tanımam (bunların dışında diğer markalar la çalışmadığımdan bilgim yok) tek dezavantajı boyutları. fakat ? serileri sorun yaşamak istemeyenler için asla tavsiye etmem ve bununla ilgili Türkiye şartlarına uygun olmadığına dair nerdeyse bir kitab bile yazabilirim. Haleb ordaysa arşın burda röle test cihazınız varsa eğer belirtilen akım ve zaman eğrileri için açma süresini hesaplayın ve röle sabit bir akımda en az 10 defa deneyin her açma süreisi için nedenli farklılıklar gösterdiğini göreceksiniz.. Zaten röle kordinasyonu ile ilgilenip bu rölenin kataloğunu üstün körü inceyip hala bu röleyi öven varsa diyecek bir şeyim yok??? teknik desteği ararsanız cevap hazır "sizden başka kimseden böyle bir şikayet yok" o rölenin teknik destek veren mühendis arkadaş bu forma hiç girmedi herhalde..
ABB ref 542 ve ref610 larla ilgili olarak bilgiye ihtiyacım var.yardımlarınızı bekliyorum
REF542+ Fena degil, fakat REF610 iyi değil scadaya veri alması zor.
REF542+'ın hangi versiyonu elinizde. PC ile bağlantıda rölenin versiyonu ile yazılım uyuşmalı. PC'ye bağlana bilmek için bir de optik seri kablosu lazım.Ayrıca birde akbil gibi keyleri var.
https://www.kontrolkalemi.net/drive/s/9wKBQB0a1LIQZ9OrMWowkM0Qz06p5M
REF542.rar
rolecilik başlı başına bir iş branş .... bigi ve tecrübe ilgili arkadaşlara kolaylıklar diliyorum...
PNC rölenin linkini savunan arkadaşlar vermemişler ben vereyim. röle hakında kullanmadığım için yorum yapmıyorum.
::: PNC TECH ::: Leader in Power Industry
Doğru söz. Yanımda çalışan arkadaşlar nasıl röleci ola bilirim bir okulu varmı dediklerinde. Ben onlara en az iyi bir rölecinin yanında 6 sene çalışmanız lazım derim.26 sene bu işi yaptım şimdide evde PC başında vakit geciriyorum.
...Aslında röle ayarları komplike değil, Ohrir'in söylediği gibi bilinen kriterler baz alındığında, röle ayarı kataloğa bakarak her türlü yapılır. Ucuz röle = Pahallı donanım konusu da piyasa ile ilgilidir. Aslında ekipmanı ile toplamda röle fiyatları yaklaşık aynı...
"Elimden gelen bukadar, demeyin,
fazlasını yapın."
Areva röleler
Protection relays
Overcurrentprotection
MiCOM AlstomP14x
MiCOM Alstom P145
P12x/y
P124
P139
Motorprotection
MiCOM AlstomP24x
P220, P225
Generator protection
MiCOM Alstom P342, P343, P344, P345,P346, P391
DLR andinterconnection protection relay
MiCOM Alstom P341
Distanceprotection
MiCOM Alstom P441, P442 and P444
MiCOMho Alstom P446, P443 and P445
Linedifferential and phase comparison
MiCOM AlstomP54x
MiCOM AlstomP547
MiCOM AlstomP594
MiCOM AlstomP59x
MBCI
MHOR04
P521
Transformer protection and control
MiCOM Alstom P642, P643 and P645
P63x
KBCH 120,130, 140
KVGC
Busbardifferential
MiCOM AlstomP740
MiCOM AlstomP746
Circuitbreaker failure
P821
Networkstability
MiCOM AlstomP846
MiCOM AlstomP847
S800 sPDC
Phasorterminal
Voltage andfrequency
MiCOM AlstomP94x
Railprotection
P436 and P438
Highimpedance restricted earth fault and Busbar protection
MCAG
MFAC
MVTP
Autorecloseand check synchronism
MiCOM AlstomP841
MiCOM AlstomP842
KAVR Series
KAVS
KVTR
Auxiliaries, trip relays, timers
MVAA
MVAJ05x/10x/20x
MVAJ 11 to 34
MVAX 11
MVAX 12, 21,31, 91
MVTT
PRiMA
Accessories
MiCOM AlstomP891
MMLZ
Communicationsequipment
KITZ 101/KITZ 102/ KITZ 103
KITZ201/202/204
KITZ 274
Engineeringtool
S1 Studio
Testequipment
MiCOM AlstomP990 series
MMLB MMLG
The numericalsubstation
IEC 61850Standard
Non-Conventional Instrument Transformers(IEC 61850-9.2)
NPAG
NPAG
Thytronic markadan hiç sorun yaşamadım.Her arkadaşa önerebilirim.
Teslimat, Teknik servis problemsiz...
Merhaba,
ABB rölelerden REF542 ve REF 610'yı kullanıyoruz. Rölelerde ısınma olabiliyor.
Ayrıca ilk etapta rölede ayarların anlaşılması da biraz karışık olabilir. örneğin aşağıda REF610'un bir ayar menüsü var.
röle üzerinden ayarlara baktığımızda sadece SGF3=120 yazıyor. sonra bunun ne anlama geldiğini öğrenmek için
120'yi kendiniz 2'lik sisteme çevirmelisiniz. İkilik sistemde (0001111) bulacaksınız bu da aşağıdaki ayarlara denk geliyor.
Ama ABB'den ilgili kişi yeterli bilgiyi kendisine verdiğinizde size yardımcı oluyor. Ayarları ve arızaları inceleyip geri dönmeleri 1-2 gün sürüyor. Ancak, çelişkili-kritik olabileceklerini düşündükleri soruları yurtdışına soruyorlar ve yurtdışından haber gelmesi uzun sürüyor. birkaç haftayı bulabiliyor.
kemli
